X-Type won't turn over
Old Jan 20, 2016 | 07:35 AM
lmitch89's Avatar
Default X-Type won't turn over
I have owned my 2002 2.0 V6 X-Type about 2 months, it was fairly cheap so isn't in the best condition but started without fail everytime...the engine always started without any issue, once started the engine ticks over a little lumpy, when driving tends to hiccup until you reach 2000 revs...last week the car just stopped trying to start, when you turn the key the dash lights up, but when turned into the third position nothing happens. We have had a bit of cold weather recently but the battery seems fine, tried to jump but still nothing. I have checked all fuses, made sure battery terminals are tight etc. Has anyone please got any suggestions, as i didn't pay a lot for the car i don't want to spend a fortune on it, would be a shame to see it go to the scrap yard.
Old Jan 20, 2016 | 07:40 AM
Welcome to the forum lmitch89,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
Old Jan 20, 2016 | 10:11 AM
joesoap's Avatar
Manual or auto?
Auto has lockout on selector so try in neutral not park?
If manual its either ignition switch or starter related.
Old Jan 20, 2016 | 10:42 AM
lmitch89's Avatar
Originally Posted by joesoap
Manual or auto?
Its a manual, when i try to start it there is no click or anything that would lead me to believe the starter was trying, the only thing that happens when i turn the key to start it is the radio powers down as it does when you start the car...
Old Jan 20, 2016 | 02:24 PM
Alfadude's Avatar
More than likely you need a new battery. They can go without warning.
As for the rough running engine, it could be a number of things, usually pretty minor and not expensive to fix. If you have a check engine light on have the codes read and post here and someone more than likely could quickly diagnose the issue and point you in teh right direction
robbing
Nov 20, 2019 01:55 PM
mbates50
Feb 8, 2016 05:51 PM
Lemons Racer
Jan 25, 2016 04:33 PM
feldona
Dec 30, 2015 03:46 AM
solostax
Dec 23, 2015 03:33 PM
