XE ( X760 ) 2015 -
Has anyone taken off their engine cover?
Old Feb 12, 2018 | 02:54 PM
BruceTheQuail's Avatar
Default Has anyone taken off their engine cover?
I dont need to do it on our XE as it is a 4 potter, but a number of f type owners (me included) have taken it off to enjoy the supercharger whine.
Look at the threads in the f type forum if you are interested, but essentially the temperature is lower under the bonnet if it is removed rather than hotter. I can hear the supercharger whine until about 3500 rpm when the sound of the exhaust takes over, but maybe in the XE with the quieter exhaust the whine will be stronger. It isnt a full on scream or anything, but if you like a bit of noise it should make you smile.
To take the engine cover off, you essentially just lift it, as it sits on little plugs. The engine isnt very attractive without the cover.
Old Feb 14, 2018 | 06:59 AM
Austin7's Avatar
Pretty much the first thing I did. Saves weight, lowers the engine temps a tiny bit. I like the look of the aluminum engine over some plastic cover any day, but that's me. Went in for a service interval without it, they seemed to care not....
Old Feb 14, 2018 | 09:22 AM
SinF's Avatar
Taking engine cover off is must-do for any kind of track use. It traps quite a bit of heat and greatly contributes to heat soak. AJ engine deals with this by adjusting timing and cutting power.
Old Feb 14, 2018 | 09:34 AM
Whitefpace's Avatar
F Type SVRs, the Project 7 and 8 cars actually all come without the cover from factory....That in itself tells you what the in house Special Vehicle performance guys think of the engine cover...
Old Feb 22, 2018 | 11:02 PM
alphakinase's Avatar
Yes since day one. Why wouldn't you?
Old Feb 23, 2018 | 12:40 AM
do you notice the whine more? i do in the f type but it gets drowned out by the exhaust
Old Feb 23, 2018 | 10:52 AM
I can definitely hear the whine, especially around 3k rpm before the exhaust lights up
Old Feb 26, 2018 | 09:46 AM
carzaddict's Avatar
took it off on my XFR, best decision ever
Old Feb 26, 2018 | 11:28 PM
steel12's Avatar
Is there any marking or wear on the sound deadening directly under the hood from the extra heat it's giving off?
Old Feb 27, 2018 | 04:05 AM
Whitefpace's Avatar
It would very much surprise me if there would be a temperature issue for the hood. On an F Type SVR there is just a minimal patch and the rest of the hood is left bare. The gap between hood and engine is also much smaller on the F Type.
Old Feb 27, 2018 | 12:47 PM
steel12's Avatar
So how do I take it off? I'll post pics for future reference since they don't seem to exist online. Can't find a picture of the xe35t engine bay without a cover on it.
Old Feb 27, 2018 | 12:51 PM
Just pull up on it gently and it will release. No screws or anything.
Old Mar 5, 2018 | 02:02 PM
steel12's Avatar
Breeze to take off. Maybe a little more whine, no changes otherwise. Definitely not suddenly annoying. Looks great though.
Engine cover off, from distance
kbeachy
Apr 19, 2017 08:21 AM
FtypeRRR
Sep 26, 2015 05:46 PM
domino_z
Aug 3, 2015 03:34 AM
scottatl
Oct 31, 2014 10:01 AM
jag79
Apr 29, 2012 03:39 PM
