XE ( X760 ) 2015 -
Warning lights
Old Jan 21, 2020 | 10:39 AM
Loulambo's Avatar
Default Warning lights
Hi ive recently had warning lights come up on the dash of my 2017 xe r-sport and when they come up the engine cuts out but the electrics are still on. The warnings are stability control not available, aeb not available, forward alert not available, engine temperature fault, lim standby intelligent mode not available, emergency brake assist not available. My jaguar dealership cant find a fault but they have the fault codes. Has anyone else experienced this
Old Jan 22, 2020 | 03:19 AM
Fraser Mitchell's Avatar
No, I've haven't had anything like this, but as the car is still under warranty it is the dealer's job to sort it out, and pronto ! My car has done 22k miles, what's yours done ?
Old Jan 22, 2020 | 08:00 AM
DJS's Avatar
DJS
Low battery could probably do this.
Old Jan 22, 2020 | 09:52 AM
Loulambo's Avatar
Its done 29k had its first service at 21k. Jaguar have replaced the coolant pump, they had it booked in for wheel sensor but then said its nothing to do with that either
Old Jan 22, 2020 | 11:51 AM
It could be an earthing problem, and the modules you list rely on that particular earthing point. Thins like this were very common on my last model of car, an XJ6 (X350 series). I never had it, but others reported the dash lighting up with faults and the source was always the earthing points at the front of the car. However, surely your dealer should be sorting this out ? I would expect a courtesy Jaguar car while they fix it.
Old Jan 22, 2020 | 04:43 PM
Daf11e's Avatar
Why did they change the coolant pump?
I’m interested as mine was changed after 8k klm.
Old May 23, 2020 | 05:14 PM
Yusuf Islam's Avatar
Hi Loumbo,
Did you fix your problem?
I have some issue now. I had change battery but all warning lights still there.
Many thanks.
XF / 2016 / 2.0D
Old May 24, 2020 | 07:52 AM
Some fault codes don't clear when the underlying cause if fixed, they have to be manually cleared. You need to get them cleared and then see if they come back when you restart the car. If they do, then you need to investigate. What made you think a new battery would clear them ?
Joedon62
Apr 14, 2021 01:11 AM
Henry37
Aug 13, 2019 06:58 AM
blackjaguarxk8
Jul 7, 2018 01:31 AM
thruxitup
Apr 10, 2015 12:38 PM
Delta66
Feb 15, 2010 09:04 AM
