XE ( X760 ) 2015 -
Xe S winter wheels
Old Dec 3, 2019 | 11:46 PM
Vanja's Avatar
Default Xe S winter wheels
Hy
I am looking for winter set for my xe s 2015, due to poor availability in Germany could someone please tell me what dimensions can i fit to my car, or maybe from some other model?
Thanks.
Old Dec 5, 2019 | 05:39 PM
Fraser Mitchell's Avatar
Have you looked on the internet for the wheel sizes you already have ? There is lots of stuff out there, and XF wheels should fit OK. I'm assuming you're not looking for perfect wheels. Use this website to check tyre diameter for a different wheel size: -
https://tiresize.com/tyre-size-calculator/
It will tell you the speedometer difference too. As an example, I swapped a set of 19" for 17" with much fatter tyres and the speedometer difference was very small. However, a word of caution - a smaller wheel may not fit over the caliper if you have large size discs. On my MG TF I have larger discs and 4-pot calipers so the smaller 15" wheels don't fit over the caliper. The 16" that I have are pretty tight already !!
joejob
XE ( X760 )
Feb 16, 2022 08:33 PM
Opi
XE ( X760 )
Nov 15, 2019 06:36 PM
Prange
XE ( X760 )
Jul 14, 2018 08:17 AM
pdupler
Apr 23, 2018 09:03 PM
ololly
XF (X260)
Mar 17, 2017 06:52 PM
