Xe S winter wheels
Hy
I am looking for winter set for my xe s 2015, due to poor availability in Germany could someone please tell me what dimensions can i fit to my car, or maybe from some other model?
Thanks.
Thanks.
Have you looked on the internet for the wheel sizes you already have ? There is lots of stuff out there, and XF wheels should fit OK. I'm assuming you're not looking for perfect wheels. Use this website to check tyre diameter for a different wheel size: -
https://tiresize.com/tyre-size-calculator/
It will tell you the speedometer difference too. As an example, I swapped a set of 19" for 17" with much fatter tyres and the speedometer difference was very small. However, a word of caution - a smaller wheel may not fit over the caliper if you have large size discs. On my MG TF I have larger discs and 4-pot calipers so the smaller 15" wheels don't fit over the caliper. The 16" that I have are pretty tight already !!
