Engine oil leak - Valve cover gasket fail
Hello all,
I noticed some fresh engine oil on the front of the engine behind the pulleys and the dealership replaced the driver's side valve cover gasket under warranty, 53000 miles on the Odo. This is definitely a premature failure I reckon.
I don't think I am alone with premature gasket failure but I did not see any posts on this topic.
2016 XF Prestige 3.0L
Cheers!!
Cheers!!
Thanks for the heads up..
Could you post a clear picture of the repair invoice so we can see the notes, parts and labor hours?
From your previous posts your Warranty looks like the Elite 60k.
I wonder if the 100k CPO would cover such a leak..
First I've read. You probably are alone.
Probably, there are just some loose bolts on the valve cover that need to be re-tighten. Unless, your engine is in a much heated stress due to rapid acceleration or has been abused. Very uncommon for such a low mileage car..
Hello all,
Cheers!!
Cheers!!
Useful, important thread!
As some of us reach 50-60k now, the CPO Warranty will be put to the test..
Reminds of the valve cover issues with the AJ-v8 on the X308..
cadfael_tex
Jul 4, 2011 06:17 PM
