XF (X260) 2015 onwards
Front bumper problem.
Old Dec 19, 2019 | 07:18 AM
vosams's Avatar
Default Front bumper problem.
2016 XF prestige
The little square box under the head light will not push back into the bumper. I pulled it out to see what it was. I don’t know. It connected to a line that goes into the bumper. After I get off work I will go to dealership to see if they can figure it out.
does anyone know what it is for? It looks ugly with it sticking out of the bumper.
Old Dec 19, 2019 | 01:52 PM
CarsonCitySmith's Avatar
Probably the insert point for the tow hook. There should be a tow hook in with your jack and spare that you screw into the bumper mount behind that square opening.
I haven't removed mine, hope never to have to.
P.
Old Dec 19, 2019 | 03:31 PM
vosams's Avatar
After work I pushed it in. It went back in place with ease. A little water squirted out when I pushed it in though. I was freaking out for a second.
thanks.
Old Dec 20, 2019 | 04:24 PM
Dregun's Avatar
You sure you didn't try to pry open your front headlight washers? The cars are equipped with headlight washers that automatically kick in after a certain amount of uses. I've never seen mine activated in person but a family member saw them after I sat pulling the wash lever a few times to make sure they worked.
Here is a post showing a picture of where they are and how they activate
https://www.jaguarforums.com/forum/x...washer-177644/
Old Dec 20, 2019 | 06:29 PM
vosams's Avatar
That’s exactly what is was. It was out this morning, so I extended it all the way out and it wouldn’t push back in. Lol It was the coldest the car has seen. (18 degrees). I wondered why it was sticking out for the first time since I had the car (4 months).
JensenHealey
Oct 24, 2016 12:48 AM
Pilotman11
Feb 6, 2016 06:19 AM
mikelu4
Jan 29, 2012 10:55 PM
GhostriderXKR08
Feb 21, 2011 01:42 PM
Mark Rogers
Jul 27, 2009 02:38 PM
