XF (X260) 2015 onwards
Mirror Dip in Reverse
Old May 23, 2019 | 01:24 AM
hcardle's Avatar
Default Mirror Dip in Reverse
I'm having problems with my mirror in that it wont dip when reverse is selected. I had a system update a few weeks ago and it seemed ok at first but now it doesn't work again.
Anyone got a fix?
Old May 23, 2019 | 08:43 AM
Brutal's Avatar
thank God its broken. I hate that feature. I don't need to look at the ground I want to see back corner of car.
Old May 23, 2019 | 11:59 AM
mleskovar's Avatar
Originally Posted by hcardle
..... I had a system update a few weeks ago and it seemed ok at first but now it doesn't work again....
First make sure you've activated that feature. If it is activated then it's broken ..... I had my mirror motor assembly replaced for the same problem but the dip is so small it's useless and I programmed seating position 3 to match 1 except for a usable dip.
Old May 31, 2019 | 01:17 PM
charles06's Avatar
As stated, make sure the feature is on. Next, put the vehicle into reverse and use the mirror control to set the dip position to where you'd like it to be. Many people don't realize that you can set the mirror position to be where you want it when dipped. Same as most vehicles with this feature.
Old May 31, 2019 | 01:55 PM
mleskovar's Avatar
Not so, though I wish it were. The dip angle is fixed. It will only dip Xdegrees from the set position.
Old May 31, 2019 | 02:07 PM
charles06's Avatar
Really? On my F-Type, it allows me to select the passenger mirror with the door controls, then position the mirror where I want it to be...while in reverse.
Old May 31, 2019 | 03:00 PM
mleskovar's Avatar
Really?.......
Really. Not what you call a good feature Don't know what they were thinking to incorporate a fixed reverse mirror dip angle.
Old Jul 13, 2019 | 10:39 PM
hcardle's Avatar
Confirmed it is a fixed position and I found out what my problem is. I'M SHORT.
Old Jul 14, 2019 | 09:38 AM
mleskovar's Avatar
..... I'M SHORT.
I'm 6 foot and it doesn't come close to dipping enough for me so I set up the 3rd button to match the first position seating and a dip that works for me.
Old Jul 15, 2019 | 04:26 AM
hcardle's Avatar
Yeah I did that too. It sorta works but would be better if you could set the dipped position.
Old Jul 15, 2019 | 09:51 AM
mleskovar's Avatar
At first that's what I thought as well but have since changed my mind. I only use the dip when parallel parking next to a curb and that doesn't happen very often. For the rest of the time in reverse no dip is better...... like when backing out of the garage or parking spots which happens much more often. To each their own.
Donm
Dec 22, 2018 04:59 PM
Greggbhill
Aug 26, 2018 11:09 PM
Pristine97XK8Convertible
Aug 25, 2017 04:15 PM
DavidT
Apr 19, 2014 09:28 PM
harryc
Feb 28, 2012 01:52 PM
