09 XF SC Supercharger Problem-Need Advice
The electric water pump on the intercooler circuit.
https://www.jaguarforums.com/forum/x...ck-off-185814/
https://www.jaguarforums.com/forum/x...r-pump-178291/
https://www.jaguarforums.com/forum/x...nation-176813/
https://www.jaguarforums.com/forum/x...solved-172713/
https://www.jaguarforums.com/forum/x...-152574/page2/
If you do replace the intercooler pump yourself, make sure you change the right one, there are two electric pumps, one for the heater, one for the intercooler.
And....
Recently I was made aware that you must use a vacuum bleeder when opening up the cooling system in these cars (especially the intercooler). My XKR took on nearly 2 litres more coolant after being vacuum bled!
Unbelievable, but I saw it with my own eyes.
And....
And....
And....
I think Cambo had in mind not watter pump but separate chargers cooling pump. this makes air very hot reduces power, but i think you still shoudl hear charger whine.
you can do experiment-
1)remoove windsheild pastics
2)add original stock exausts(if you have any aftermarket)
3)drive car to full rpm
you shoudl hear supercharger swisting easily. if its not there and belt is driving it then something really stange has happened to your SC..
Rocky15
May 13, 2016 10:25 AM
Kevlar9281
28
Mar 16, 2016 12:07 AM
klfong
Nov 11, 2012 10:07 PM
