09 XF SC Supercharger Problem-Need Advice
Old Mar 2, 2018 | 08:50 PM
Cambo's Avatar
Old Mar 2, 2018 | 09:15 PM
Supercharged Jag's Avatar
That was my next guess, I'll definitely have a look at that. Honestly, I'm just an 18 y/o that has a bit of knowledge, not that much, but some. I try working on the car myself to save money and gain some knowledge. I've replaced quite a bit of things myself. All the help is appreciated.
Old Mar 2, 2018 | 09:39 PM
Cambo's Avatar
If you do replace the intercooler pump yourself, make sure you change the right one, there are two electric pumps, one for the heater, one for the intercooler.
And....
Recently I was made aware that you must use a vacuum bleeder when opening up the cooling system in these cars (especially the intercooler). My XKR took on nearly 2 litres more coolant after being vacuum bled!
Unbelievable, but I saw it with my own eyes.
Old Mar 2, 2018 | 10:04 PM
And....
I definitely will, thank you for all the help
Old Mar 3, 2018 | 01:23 AM
elviukai's Avatar
Originally Posted by Supercharged Jag
I just had the water pump replaced about 2 or so months ago
I think Cambo had in mind not watter pump but separate chargers cooling pump. this makes air very hot reduces power, but i think you still shoudl hear charger whine.
you can do experiment-
1)remoove windsheild pastics
2)add original stock exausts(if you have any aftermarket)
3)drive car to full rpm
you shoudl hear supercharger swisting easily. if its not there and belt is driving it then something really stange has happened to your SC..
Old Mar 3, 2018 | 02:28 AM
other people have reported, such as the links Cambo provided, that they were having the same problems if not similar as mine, and they replaced the intercooler pump “supercharger pump”. After that the Supercharger started working again and felt the boost. Also a lot of people have changed it prior, around 50k miles because it is one of those things that is almost guaranteed to go out. I will check everything and do some more research before replacing parts, But I might use that way to test it out. Thanks
Old Mar 3, 2018 | 08:36 AM
jackra_1's Avatar
Deleted as irrelevant!
Rocky15
May 13, 2016 10:25 AM
Kevlar9281
28
Mar 16, 2016 12:07 AM
klfong
Nov 11, 2012 10:07 PM
hughey
Apr 9, 2011 08:14 AM
princemarko
Mar 13, 2010 05:35 PM
