2010 Jaguar XFR 5.0 radiator fan not working
Old Apr 5, 2021 | 07:08 PM
Turtlepower's Avatar
Default 2010 Jaguar XFR 5.0 radiator fan not working
Hey Guys, So my radiator fan has stopped working. Engine overheats at idle, and AC cold air turns warm. Everything corrects itself once car is moving and cool air goes through the radiator. When I turn AC on, the fan doesn't turn on. Is there anyway for me to pinpoint my issue? Is it the whole radiator fan assembly? Maybe just a switch or some wiring? I have an Icarsoft LR v2.0 scanner.. are there any tests I can run or data I can see that will help me pinpoint a culprit?
Old Apr 5, 2021 | 10:11 PM
JBzXJ40's Avatar
If you have a scanner, try scanning PCM to see if you get any codes
Try checking the fuse - 30A mini fuse, Engine junction box #42
Also check the ground behind/below the RH headlamp assembly, clean the ground stud and eyelets from the wiring and reassemble, then recheck to see if the fans come on
Lets see what you get first then dig deeper if we have to
Old Apr 5, 2021 | 11:37 PM
OzXFR's Avatar
Do you have a copy of the Workshop Manual?
If not you can get it from my Dropbox here: https://www.dropbox.com/s/bet26xniua...kshop.pdf?dl=0
Without checking I am fairly sure it contains the procedure for diagnosing and fixing your problem.
Old Apr 6, 2021 | 11:41 AM
davetibbs's Avatar
In my experience, most if not all cooling fan failures are down to failure of the fan control unit which is built into the fan itself, and unfortunately I have not been able to find a suitable replacement for just the unit, or indeed how to repair it. The control unit receives a PWM signal from the ECU, which dictates the duty cycle that the fan needs to spin at, and the control unit varies the fan speed accordingly.
This leaves two options, either finding a used fan from a breakers, or buying one new, and the prices are basically offensively expensive for what is just a cooling fan, with even non-OEM copies going for $900.
Old Apr 6, 2021 | 11:48 PM
Wow guys thanks for the advice, will try to work through this , this week. Will report back my finding (if any).
In case I need to resort to finding a cooling fan assembly to replace, are there any compatible cars I can look at? Any compatibility between the naturally aspirated 5,0? Or the range rover 5.0 supercharged ?
Actually from some shopping in rockauto, I have found that the 5.0 NA and 3.0 SC share the same part.
Here are some options from rockauto
https://www.rockauto.com/en/catalog/...cooling+system
https://www.rockauto.com/en/catalog/....0l+v8,1444765
https://www.rockauto.com/en/catalog/...+assembly,2181
Old Apr 7, 2021 | 10:59 AM
clubairth1's Avatar
Community Influencer
Well be careful about the used ones on Ebay. Here is one for $290 with a broken mounting tab they don't tell you about!
Cooling Fan
Sorry this was for an XJ which seems to have a different fan assembly?
They are listed as for XF,XJ and F-type but not sure they are all the same?
Here is an early 2009-2010 XF unit. Maybe this would work?
Cheaper at $210 plus $30 shipping.
XF Cooling Fan
I guess check to see what yours looks like before shopping.
Old Apr 12, 2021 | 04:38 PM
davetibbs's Avatar
I'd still take that one with the broken mounting tab so long as the fan itself works - it's trivial to swap the fan motor/blades from the replacement into your original housing with a working tab.
Also that second fan is (I imagine) for a 4.2l engine as the fan motor/connector is different, so it won't work for this application.
Old Apr 13, 2021 | 10:04 AM
clubairth1's Avatar
Good to know and I had contacted the vendor so he would not sell a bad part. He removed the ad for the entire fan shroud and planned on listing just the motor/blade assy. If you contact him I am sure he will sell you just the motor/blade assy. Probably even cheaper!
Old Mar 8, 2022 | 11:08 PM
ozmandous's Avatar
Default Who wants to pay 1000 bucks for a new fan assembly
Look, I didn’t want to pay out the booty for a new assembly. So I found a high flo fan from auto zone. Wired it to a toggle switch going from the original radiator fan hot and ground and now I have had a good working fan for 6 months with no issues. It doesn’t throw a engine light but it does show a fan control code with a code reader, but no pesky check engine light to bug me and I just remember to hit the switch when I’m idling. Problem half solved. I suppose I’ll worry about a oem one if I decide to ever sell it. But I probably wont
2010 Jaguar XF 5.0 n/a over here in Ohio.
Mikesxf
Jul 18, 2024 06:36 PM
Supercharged Jag
Apr 27, 2021 06:29 PM
sjgh
Jan 26, 2014 03:23 PM
BALTVISTA
Oct 11, 2009 11:01 PM
BALTVISTA
Oct 9, 2009 03:22 PM
