2010 XF Ambient Air Temperature Sensor?
Old Nov 24, 2017 | 03:44 PM
Lyn Askin's Avatar
Default 2010 XF Ambient Air Temperature Sensor?
2010 Jaguar XF 5.0L
Can someone point me in the right direction? My ambient air temperature shows -40F pretty consistently. I'm getting a P0071 and P0073 fault and a check engine light which leads me to the ambient air temperature sensor. The problem is i have no idea where this thing is.
Can someone point me to a guide/manual/tutorial where I might be able to swap out my ambient air temperature sensor?
Thanks in advance!!
Lyn
Old Nov 24, 2017 | 04:03 PM
JagV8's Avatar
On mine it's behind where the front number plate (licence plate) is (or would be if you don't have one). Quite cheap, easy to swap.
You have near enough the same car... (and I think the workshop manual is on here somewhere if you look)
Old Nov 24, 2017 | 04:46 PM
Lyn Askin's Avatar
Great. I'll look for the manual. Thank you!
Old Nov 24, 2017 | 06:10 PM
OzXFR's Avatar
Here's a link to the 2010-2011 XFR Workshop Manual:
https://www.dropbox.com/s/bet26xniua...kshop.pdf?dl=0
Yes, it's for the XFR but it covers the 5.0 NA as well.
PS - on both my XFs the ambient temperature sensor was on the underside of the LH exterior rear view mirror.
Old Nov 24, 2017 | 09:23 PM
Lyn Askin's Avatar
Thank you so much!
Old Nov 27, 2017 | 06:59 PM
kkurulak's Avatar
The part number I believe is C2Z5465 if that helps, you can also check the Jag parts catalog.
Old Dec 4, 2017 | 05:12 PM
Lyn Askin's Avatar
I have replaced the ambient air temperature sensor in the mirror, but my reading on the climate dashboard still shows -40F .Is there anything else I need to do to reset it, or was that not the problem in the first place? Thoughts?
Thanks in advance.
Lyn
2010 Jaguar XF Premium Luxury
Old Dec 6, 2017 | 05:46 AM
JagV8's Avatar
Next suspect: wiring & connectors.
Old Dec 9, 2018 | 05:17 PM
Jayhawk5763's Avatar
Default Ambient Temperature Sensor
Did you happen to find out the cause if your issue?
Old Dec 9, 2018 | 10:03 PM
Lyn Askin's Avatar
I did not. I swapped out the sensor with no solution. I haven't gone any further.
Old Dec 10, 2018 | 10:46 AM
clubairth1's Avatar
Community Influencer
Might take a dealer level scan tool because I bet there is a high level code set somewhere.
I would be worried that my heat and A/C would go nuts trying to work with a -40 outside temperature?
Does the automatic climate control work OK?
Old Dec 10, 2018 | 10:51 AM
Lyn Askin's Avatar
The dealer scanned it and said the ambient air temperature sensor needed to be replaced. But they didn't have it in stock. I do have another new one here that I ordered. I may try replacing it again myself.
The auto climate does not work that well. You're right, the outside temperature definitely makes it act a little crazy. So, I basically leave my temperatures set to LOW and just turn the fan all the way down if its too cold. ;-) Its a pain, but I dont know if i feel like replacing all the wiring in the door etc. I'm not sure what my options are at this point.
Does anyone else have this issue?
Old Dec 10, 2018 | 08:28 PM
Bigg Will's Avatar
Did you try disconnecting and reconnecting the battery?
Old Dec 11, 2018 | 11:53 PM
May I ask who told you that it may a be a problem with the wiring in the door? Also which door (assuming it's the driver), is this were the sensor is located?
My XFR was in an accident on the driver side, so I'm trying to figure out what's happening as well.
Old May 26, 2019 | 08:11 PM
Karim Lattafi's Avatar
bonjour, vous avez trouvé la solution?,j'ai le même problème sur ma XF 2012 2.2td,ma climatisation ne fonctionne 😓
Old May 26, 2019 | 11:44 PM
lotusespritse's Avatar
hello, you found the solution?, I have the same problem on my XF 2012 2.2td, my air conditioning does not work
Old May 22, 2020 | 05:06 AM
pauledddy's Avatar
Any solution to this? My xkr is doing the same thing
Old May 22, 2020 | 12:54 PM
Richard Zuniga's Avatar
do you have one for the 12 model year?
Old May 22, 2020 | 05:58 PM
OzXFR's Avatar
No.
I'm fairly sure that 10/11 manual is the last one ever published as a single PDF and from then on in it was tOPIX or nuffin.
Old Nov 13, 2020 | 03:32 PM
64th note's Avatar
On my 2011 XF, there are 3 temperature sensors: one on each side mirror and one in front grille. One of the three could have gone bad.
