2012 Jaguar XF Lowering Options and Installation
Old Dec 27, 2012 | 03:45 PM
Sick XF's Avatar
Default 2012 Jaguar XF Lowering Options and Installation
So far I have done everything but suspension. I am contemplating either the Eibach or H&R Springs. I am curious to member feedback with these two manufactures? I also wanted to know if anyone can shed some light on the easiness of installation. I have done springs before and from what I see the front seem pretty simple. Not sure on the rear as I haven't looked into the rear details. Any help would be appreciated.
Old Dec 27, 2012 | 05:19 PM
chXFS's Avatar
I would like to know opinions too. I have seen what the H&Rs look like but would like to see the Eibachs as well. Which is lower? Here is the link of the member who has H&R installed with 20" wheels.
https://www.jaguarforums.com/forum/s...ewpost&t=86947
Old Dec 27, 2012 | 05:32 PM
Sick XF's Avatar
I think I will order the H&R. Price is better and from what I am hearing no real noticeable difference in ride between Mina, Spire, Eibach or H&R. My big question is can these be installed easily or is it a huge pain? I got a quote for $400 to install with alignment which seems pretty steep.
Old Dec 27, 2012 | 09:43 PM
sir2's Avatar
I went with the H&R because they were the lowest (height). Springs are pretty simple to install. Just remember to reinstall that small washer on the strut rod.
$400 seems like a good price for labor and alignment. At a dealer you're looking to pay over $400 just for labor only.
I also included instructions for the rears, if you decide to do it yourself.
File Type: pdf
Old Dec 28, 2012 | 11:01 AM
Sick XF's Avatar
sir2,
Outstanding. Based off those instructions I think I am ok with doing it. Then take it in for alignment. $400 bucks is worth it considering I am trying to get Jag @ ECU Tuning to do my tune. I can use the extra money. Would you be able to get me a copy of front installation instructions and rear truck trim removal? That would make my life much easier.
Thank You!
Old Dec 28, 2012 | 12:21 PM
chXFS's Avatar
Also, where can I find the spring compressor tool in the diagram?
Old Dec 28, 2012 | 12:27 PM
Sick XF's Avatar
chXFS,
I have rented those before from autozone/ auto parts store. They work a little different but same concept. These ones grab the spring form the outside and compress. But they work and are easy to use.
Executive's Avatar
The only place i have seen the one is the PDF is in Automotive shops.
They sell removal tool kit at Auto parts stores, but i don't recommend using them - way too dangerous.
Remove them from the car and bring them to a shop, let them switch them out for you. It will take them no more than 5 minutes for all 4.
rvdz
Dec 7, 2019 06:42 AM
Johncy2000
Aug 5, 2019 07:20 PM
Fraser Mitchell
Oct 1, 2015 04:06 AM
Goncalo Proenca
Sep 8, 2015 06:06 PM
ronald4313jm
Sep 7, 2015 01:16 PM
