3.0 Vs 5.0 coolant crossover pipe?
Old Jan 27, 2023 | 09:40 PM
Jagboi64's Avatar
Default 3.0 Vs 5.0 coolant crossover pipe?
I have a 2013 XF 3.0 AWD and it has been leaking coolant. I'm planning to replace everything plastic, but the rear heater crossover pipe is on indefinite backorder at Jaguar, with no ETA, same with Land Rover. I see the part number for the 3.0 is AJ814053 and that's out of stock at Rockauto for the aftermarket version.
However, there is one in stock that appears for be for the 5.0 only in the XF, but is also listed for the F Type 3.0. Part number is AJ814007. Does anyone know what the difference is between the 3.0 and 5.0 version and will AJ814007 work on my XF?
Old Jan 28, 2023 | 03:01 AM
Robtrt8's Avatar
See if the new URO metal replacements are available.
Old Jan 28, 2023 | 10:44 AM
Jagboi64's Avatar
The Uro replacements are plastic. The front Y pipe is available in metal, but not the rear.
In any case, the Uro plastic seems to be out of stock at places that have reasonable shipping. I refuse to pay $219 shipping on Ebay.
Old Jan 28, 2023 | 09:44 PM
dennis black's Avatar
i made some YouTube videos on how to install the cooling pipes ,but the channel is down trying to recover the videos ,so i started a new channel ,ive done a few F-TYPES AND XFs with the metal pipes and the heater manifolds , until i get my videos back for now im doing another F-TYPE and ill make another VIDEO for you guys ,you just need the right tools
Old Jan 28, 2023 | 09:58 PM
OzXFR's Avatar
Thanks Dennis, I have been wondering for a long time if that rear heater manifold was the same or different on V6 vs V8, and now I know they are different!
I just checked mine (V6 F-Type) and yes each end where it is mounted has three bolts not two like the V8 version, and of course the V6 version has longer extensions to account for the shorter V6 SC body.
Old Jan 28, 2023 | 10:12 PM
Jagboi64's Avatar
Thanks for the photos, that makes it very clear!
Old Jan 29, 2023 | 09:45 AM
kansanbrit's Avatar
Originally Posted by dennis black
Useful info.
Old Jan 29, 2023 | 06:45 PM
No problem, to all Xf xj And F-type owners, I would replace this part immediately, if you do it yourself it's free plus parts ,at the Dealer $800 ,this will destroy your engine, I've been doing at least 3 subscribers per month for peace of mind,then I replace the plastic pipes with metal ones
Old Feb 7, 2023 | 06:01 PM
Jssaab's Avatar
SIde question Dennis, where did you get that spoiler, very unique...
Old Feb 8, 2023 | 09:10 PM
I got it from EBAY easy install here's my video how to
Old Jul 17, 2024 | 02:36 AM
NapaJag's Avatar
Default Question for Dennis Black
Can you please list all your metal pipes and your other components (ie, yellow supercharger spindle, etc) that you switched out in your white XF-S to bullet proof the engine. I’d like to do the same thing to my newly purchased 2013 XFR 5.0 L.
Did you also change your upper and lower pulleys on your SC? If so, please also provide these parts. Did you upgrade the belts too?
Thank you!
Old Jul 19, 2024 | 09:24 PM
My mods are Hp Transmission tune VelocityAP upper and lower pulley my Draggy best is 0 to 60 to 3.6 on a V6 SC Aj126 engine, here's some videos for parts and install ,drove to Ohio 1300 miles and a additional 600 miles so the pipes and solid coupler are a dream to have knowing I can go anywhere without any worries
here's my videos
I'll be making another video for a better parts list with reputable companies, I've advised everyone when receiving your front pipes to get Jaguar Oem O,rings for better fitment, all the F-types and Xjs I've done I do the same procedure factory O,rings ,when you get the rear metal pipes check the passage ways, Save some time out your day to watch the videos from beginning to end so you don't miss any tips
tapau
Jan 21, 2022 05:07 PM
chris.schneider
Dec 15, 2020 04:28 AM
UltBlkXF
Aug 10, 2020 11:00 AM
Stuart Satter
Mar 8, 2020 09:41 AM
Ter11
Nov 17, 2018 02:36 PM
