3.0 xf sound compared to f type
Old Apr 3, 2014 | 08:04 PM
Customgtrs's Avatar
Default 3.0 xf sound compared to f type
The f type 3.0 supercharged sounds pretty wicked compared to the xf 3.0. Is there an exhaust upgrade that will change the xf like Mina?
Old Apr 3, 2014 | 11:10 PM
07XKJaguar's Avatar
Mine sounds the same. Even the clunky sound when you shut it off. I'm guessing it's the supercharger. The first F type my local dealer got in was a 3.0 SC. I swore I'd never own one. Now I have a 14 XF 3.0 SC. I actually like the sound and the performance.
Old Apr 4, 2014 | 05:52 AM
Customgtrs's Avatar
i know this says 380 hp so there must be a little difference but I wouldn't think the compression would be lower. I bet it is a super charger pulley thing. my xf 3.0 sounds nothing like this.
Old Apr 5, 2014 | 04:29 PM
Macedon's Avatar
Would love to know if this exhaust is available for the XF 3.0!!
Old Apr 5, 2014 | 07:59 PM
jagular's Avatar
The only difference is the software, the torque figures are very close.
The F Type S is quicker because of a time tested drag strip technique: if you can't get more torque fit a lower rear end.
The exhaust sound of the base F Type is almost identical to the XF 3.0
The noisy one uses an active exhaust muffler, as does the Corvette for example and no you can't just fit one. It uses electrically controlled baffles to reduce the muffling under some conditions.
Old Apr 6, 2014 | 08:24 AM
Macedon's Avatar
The F-Type has a 340hp v6. F-Type S has a 380hp v6 with active exhaust system. And no, it won't fit the XF. The F-Type's exhaust is a single unit, large muffler that is horizontally mounted at the rear of the car. I hope an aftermarket vendor can replicate that sound of the F-Type S model for the XF 3.0. Curious to hear a before and after of the MINA exhaust people are using for their v8's fitted to the v6 XF. I've heard v6 Mustangs fitted with dual performance exhaust designed for the v8, and it makes me want to throw up.
Old Apr 6, 2014 | 11:41 AM
Bellanca_XF's Avatar
I'm guessing that going forward with the next XF, and maybe the XE Jaguar will offer the switchable exhaust as they do with the F-Type.
Old Apr 6, 2014 | 01:43 PM
Macedon's Avatar
Could be... The spy shots of the XE show exhaust tips that are closer together. It makes sense from economy of scale to consolidate as many parts as possible across the family of cars.
Old Apr 6, 2014 | 04:47 PM
jagular's Avatar
Not usually made an option on a sedan. Does the XFR S have it? If not then I doubt the XE will.
The same effect, more or less, can be obtained by cutting two 2 inch round holes in the muffler can, but then the car will be noisy all the time.
The active exhaust isn't where the additional power comes from, by the time the exhaust gets to the muffler can it is flowing pretty smoothly already.
The F Type S just has a little more boost pressure cranked in at the higher rpm range, and it's mainly paper horsepower. The acceleration difference comes from the differential ratio. The diff's in the diff.
Old Apr 6, 2014 | 05:25 PM
Yeah I'm aware that the active exhaust doesn't change the power. Anyway, just because it isn't available doesn't mean that they won't offer it going forward. They're supposed to be coming out with their "R-Sport" line, seems like a perfect place to offer such a thing.
Old Apr 7, 2014 | 05:44 AM
Customgtrs's Avatar
I have seen the electric cut out that can be installed that would probably do the trick. I just think every once in a while it would be nice to be loud...I drove the f type v8 Saturday...Dear Lord that thing is a beast and the sound......
way2far
Aug 31, 2022 09:26 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
allenman85
May 10, 2021 03:11 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
dcvickers
Sep 2, 2015 06:14 PM
