Brake caliper powder-coat
Old Feb 9, 2016 | 11:02 PM
Cherry_560sel's Avatar
Default Brake caliper powder-coat
Ok. So since I have been brought back from the edge of NOS, I have been trying to figure out where I can make a nice, tasteful upgrade. Then I looked at the fresh silver calipers and thought hey.....Powder coat these bitches!!! Can it be a simple job of having them removed, sent to the sprayer, and then reattached...along with a drain and refill of the brake fluid of course. If it's going to involve removing seals and all that then forget it. Might as well buy new freaking calipers....and no, I will NOT paint them with cans of spray paint or any other kind of canned paint. TIA.
Old Feb 9, 2016 | 11:07 PM
OzXFR's Avatar
Yep, fairly simple job to remove them and send off to be powder coated, no seals to muck about with.
You just need a 9 mm hex driver for the front caliper pins, and they can be hard to find as no hex driver set I know of (except maybe exorbitantly priced SnapOn) includes a 9 mm.
Old Feb 9, 2016 | 11:24 PM
sssSSSSWWWeeetttt!!!
Hahahaha....I am so stoked to hear that!
Old Feb 10, 2016 | 08:36 AM
kwiksilver's Avatar
An easy fix might be to get red caliper covers. I've seen them for Jag, at about $200, but I don't know if they would look cheesy or not.
Old Feb 10, 2016 | 09:39 AM
Injekter's Avatar
if you have OEM wheels you are not going to see the calipers very well, not sure what covers are available. for your breaks, ive seen brembo style covers ...its pretty easy to pop off 2 wheels at a time, clean mask and spray them yourself...they come out very nice..and you would never be able to tell the difference from paint or powder coat...if you dont wanna do that , those wheel repair shops can do it too..way less hassel then taking them all off yourself...dont get my wrong i like powder coat , but for this i dont think its worth the effort . here is my bike waiting for powder coat parts to return
Old Feb 10, 2016 | 12:54 PM
Right on dude. But when you get those forks and handles bars back, all nice and powder coated, you know they are going to look bitchin'. I also know from experience that the paint method is not that easy as it take many many coats of paint and several coats of clear coat to avoid peeling in a few weeks. After all that work, the paint Most likely will peel of anyways, unless you just etched the hell out of the calipers, which means you most likely spent days on it if you did it correctly. I am willing to take them off, send them in and get them back in a three day turn around and have nicely done calipers that will stand out. I have calevera wheels btw, and they will show through just fine. I don't like the 3-5 spoke look. For me it's not my style. My 19" Caleveras are pretty distinct and have a refined look that fits my XF. Hope you get your bike put back together. I used to ride and I miss riding!
Old Feb 10, 2016 | 02:06 PM
2010 Kyanite XFR's Avatar
I hope you don't have the calipers just hanging like that for days I realize that might have been a "during" photo and you've secured them, but if not, do yourself a favor and do so.
At the very least just get a wire coat hanger or something to take the weight off the lines and fittings. Would be a bad day if brake fluid ended up all over the tire or bike because of the added stress of hanging there.
Old Feb 11, 2016 | 06:08 PM
Injekter's Avatar
YEA, NO. that was right after i pulled the wheel and forks,, the calipers are resting up in the frame
Old Feb 11, 2016 | 09:50 PM
Glad to hear it
scuby
XJ40 ( XJ81 )
Feb 15, 2016 08:46 AM
sparkenzap
Feb 11, 2016 04:58 PM
PVK
Feb 11, 2016 02:21 PM
cyber3d
Feb 11, 2016 08:18 AM
RoonieQ
Feb 9, 2016 05:51 AM
