Car won't lock?
Old Nov 10, 2014 | 12:52 PM
Maddshadez's Avatar
Default Car won't lock?
Hi folks, I've had my XF Premium (N/A) for a couple weeks now and I've noticed in the past week that I can't seem to lock the doors. If I use the door handle it beeps twice at me like a door is open or something, but I get no open indicators from the dash. If i attempt to use the key fob nothing at all happens, no beeps at all. Even trying to turn on the lights with the fob doesn't work, however the car will recognize the fob when starting or when I'm opening the trunk, or the doors if I've manually locked them, which leads me to believe the fob batteries are ok. I tried both fobs with the same results. Any ideas what to look for next? Could both key fob batteries be coincidentally dying at the same time? Thanks in advance!
Old Nov 10, 2014 | 01:31 PM
Blackcoog's Avatar
Try holding the key further away from the door when you press the button on the door lock the car. The car might think the key is still inside the car when you are trying to lock it.
If that works you might be able to keep the key in the pocket furthest away from the door when locking the car.
Old Nov 10, 2014 | 05:35 PM
nasa25's Avatar
You might have a sticking door lock or a door lock actuator is on its way out. Physically push each door lock open and closed (chrome lock piece on the inside of the door). This will fix any sticking lock. If that doesn't cure it, might be a failed actuator.
Also change both batteries to be on the safe side.
Old Nov 11, 2014 | 07:16 AM
Maddshadez's Avatar
Nasa25 you hit the nail on the head. I went around to manually lock each door and the rear drivers side switch just flops back and forth, clearly broken. Now i just have to hope the dealer will cover it's repair under their 2 month warranty, otherwise my next question will be on removing door panels! Thanks again!
Old Nov 12, 2014 | 08:26 PM
nasa25's Avatar
Glad that you found the culprit. I had a similar issue with my rear drivers side door, although I was getting the door open warning on the dash. In my case it was just a stuck lock and the issue hasn't reoccurred. The dealer should be able to cover this unless the warranty is just power train. Good luck.
Old Nov 13, 2014 | 05:14 PM
Maddshadez's Avatar
No luck on the warranty front, so I decided to take a look for myself. Using instructions found on this site i popped the door off and sure enough, the locking mechanism popped off. I put it back where it belonged and everything is right as rain, and for free!
Old Nov 14, 2014 | 07:20 AM
nasa25's Avatar
Awesome! Good on you for doing the DIY fix.
Old Nov 14, 2014 | 07:58 AM
New Jag Guy's Avatar
Glad to have read this post. I have the same exact problem and I thought it was the battery in the FOB. Now I will go check the doors themselves. Thanks!
Old Nov 23, 2014 | 07:50 AM
PiersB's Avatar
Default Message for smart key battery
BTW - You'll get a specific message on the message center if the smart key battery needs replacement. I had one key that was almost never used. I went to use it and got the message. Replaced both batteries in a few minutes.
Old Nov 23, 2014 | 09:04 AM
Maddshadez's Avatar
Oh cool I didn't know that, thanks for the info!
Old Oct 12, 2021 | 01:35 PM
ScrotalHarum's Avatar
Question Where did you find that guide please?
Hello Maddshadez,
I have done a search but I am new to this forum so not sure, please could I ask where you saw a guide on the forum to removing the door cards ?
Kind regards.
Scrotal.
Old Oct 12, 2021 | 02:43 PM
John Williams's Avatar
Old Oct 12, 2021 | 04:34 PM
gumby7734's Avatar
Originally Posted by John Williams
You'll get it if the wire for the trunk lock breaks as well... Had it happen... Luckily the camera wire had broken so I found it during the repair, it was driving me nuts...
Old Oct 29, 2021 | 09:22 PM
vfrman's Avatar
I hate to resurrect this thread, but what happens when you've replaced 3 of the 4 door lock actuators and the car still won't lock? I try the keyfob or the black button on the door handle and I get a beep, followed by a double beep. Also ,the buttons on the dash won't lock/unlock the car. I can hear the gas door unlock tho. I highly doubt it's the last door lock actuator. And FWIW, I had a mechanic with the OBD interface tell me it was the actuators, otherwise I wouldn't have wasted my time/money on changing those. Is there anything else I should be looking at?
Old Oct 30, 2021 | 08:01 PM
BritCars's Avatar
Have you pulled the codes? It will tell you which one is not working.
Old Oct 30, 2021 | 08:55 PM
vfrman's Avatar
The mechanic pulled the codes and told me which ones were out. I replaced them and it’s still not working.
Old Oct 31, 2021 | 07:29 PM
BritCars's Avatar
So what codes are coming up now?
Old Nov 1, 2021 | 01:46 AM
litteredwithfaults's Avatar
Hood, trunk and even gas cap have sensors and/or actuators that may not show a code for a physical fault but will prevent all the doors from locking. Just the manufacturer prioritizing revenue from dealer visit to figure it out, above your ability to secure your vehicle.
Old Nov 1, 2021 | 07:41 AM
Gus's Avatar
Gus
I experienced the same problem with my 2010 XF. Attached is a link on what I did to identify and correct the problem.
JagRepair.com - Jaguar Repair Information Resource
Gus
Old Nov 1, 2021 | 11:05 AM
clubairth1's Avatar
Community Influencer
Those ALL set codes. That's the problem with trying to fix your car by throwing parts at it. All the door actuators set codes. It's the only way to properly fix the car.
Get it hooked up to SDD and find out what the car is telling you. But first do follow Gus's excellent suggestion and lubricate all the latches to see if it's something simple.
No need to go to a dealer.
