CEL (MIL) light and mystery fault
Old Mar 21, 2009 | 06:59 PM
jagular's Avatar
Default CEL (MIL) light and mystery fault
Finally, a fault has shown up on my XF. The CEL illuminated one morning for no apparent reason. The dealer reset it within an hour. Nobody knows why the XF throws this code "air injection system" (O forget the numbers). They call it the Springtime fault and sure enough it occurred yesterday.
This XF is magic. I love the way it drives. It is reliable and seems to be built like a bank vault.
Looks fantastic after cleaning a few weeks of winter grime off the car today. Winter returns tonight though as we are expecting snow again!
Old Mar 21, 2009 | 11:17 PM
Brutal's Avatar
so far, this may be a "needs a software rewrite" ie parameters are too tight and setting a code that shouldnt be, although there are issue with the XK (same platform) that are lines burned on the EGR pipe, vacuum line disconnected, bad solenoid. The only real issue with new cars is finding what causes the faults and fixing them. Not that later years dont have problems, you just know where to look the first time....
Old Apr 19, 2009 | 01:19 PM
jagular's Avatar
Default CEL on again
This time with a faint buzzing or whining noise from the fuel tank area which stopped shortly after I opened the gas cap.
No ideas from Jaguar yet.
The demonstrator I drove almost a year ago also had the CEL light on.
Old Apr 23, 2009 | 11:05 PM
jagular's Avatar
Same issue as before and no explanation other than this fault shows up in my local area and not elsewhere. The current theory is gasoline formulation which does change dramatically twice per year from winter to summer formulations. Our Spring doesn't happen until late May so we are still using winter gasoline, it was minus 10C this morning with snow and ice.
Old Apr 27, 2009 | 07:16 PM
jagular's Avatar
Default Code P0411, no identifiable cause
Jaguar Canada has no idea how to stop this from re-occurring.
Old Apr 30, 2009 | 09:09 PM
jagular's Avatar
Default And again today
Wrote to my dealer asking for a solution this time.
Old May 4, 2009 | 04:48 PM
jagular's Avatar
CEL went out by itself today some time. Weird.
Old May 4, 2009 | 11:30 PM
Brutal's Avatar
after so many key cycles if the ecu doesnt continue to see the fault it turns of the light on many codes, but stores it in history
Old May 5, 2009 | 09:53 PM
jagular's Avatar
Thank you.
Jpav27
Jul 31, 2022 06:43 AM
Mugatu
22
Jun 23, 2020 01:50 PM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
