Cheee!! XKR-S map loaded on to my XF S/C
Old Oct 31, 2012 | 07:46 PM
sir2's Avatar
Default Cheee!! XKR-S map loaded on to my XF S/C
Flashed it, can't really feel a difference. My friend has a dyno at his shop so hopefully he'll have time this weekend to check and see if the flashed actually worked. I've already done a base run at 401 whp. From what my diagnostic machine says, it does state I have the xkr-s map.... so "cross fingers" hopefully it worked.
Old Nov 1, 2012 | 08:37 AM
Blackcoog's Avatar
How did you you have it flashed?
Old Nov 1, 2012 | 04:09 PM
XF - Xtra Fast's Avatar
I was initially curious how he flashed his car too, but then I noticed in his Sig its a 2102 so hes obviously posting from the future DUH
Old Nov 1, 2012 | 04:44 PM
jlocc619's Avatar
Great Scott!
Old Nov 1, 2012 | 04:51 PM
Blackcoog's Avatar
Ha!
Old Nov 1, 2012 | 04:57 PM
Cambo's Avatar
Time travel is not logical...Captain...
Old Nov 1, 2012 | 05:27 PM
sir2's Avatar
Hahaha thanks for the heads up. Didn't realize the typo.
Old Nov 1, 2012 | 05:38 PM
sir2's Avatar
If the flash works, I'm a step closer.
Old Nov 3, 2012 | 12:07 AM
sir2's Avatar
dyno is set for sunday.
Old Nov 3, 2012 | 03:52 AM
dsmith's Avatar
Originally Posted by jlocc619
Great Scott!
Can you mind posting a photo of your XFR with the black rims so I can see it better. I've given a little thought to blacking my rims but would love to see photos of another black XFR with black rims before I spend any cash.
Thanks,
Darin
Old Nov 4, 2012 | 07:58 PM
sir2's Avatar
Just got it dyno'd. Max hp 420, max tq 440. Seems to peg rich in the higher rpms..
Old Nov 5, 2012 | 12:34 AM
What dyno brand? corrected/uncorrectee?
Old Nov 5, 2012 | 04:53 AM
sir2's Avatar
it was on a dynojet
Attached Thumbnails Cheee!!  XKR-S map loaded on to my XF S/C-dyno2.jpg
Old Nov 5, 2012 | 08:24 AM
BigCat09's Avatar
This sounds to be on par with the XFR. They make it go pig rich in the upper rpms all the time to cool the cylinder walls and such. This is a good and safe thing to do.
I will guess that your 20whp increase takes you into XFR grounds now I would think rather than a XKR-S.
How much did this cost? I bet ifyou needed to go to the dealer for issues or quirks they will be confused on how to flash it as it reads XKR-S and your cars VIN is a XF? Might get a bit hairy for a tech?
Old Nov 5, 2012 | 11:32 AM
sir2's Avatar
I did the flash myself, so I only had to pay for the dyno. My car doesn't read as an xkrs (vin) at all. A regular tech would not know this car has a xkrs map, unless they dig really deep. I was easily able to flash it back to stock for a base run, then reflash it with an xkrs map to see the difference.
Old Nov 5, 2012 | 12:56 PM
jlocc619's Avatar
Thanks,
Darin
Don't want to hijack the thread, but here you go. PM me if you want additional details. I will be doing a little photo shoot after I get my goodies from Mina.
jlocc619XFR by jlocc619, on Flickr
-Jason
Old Nov 5, 2012 | 01:39 PM
Originally Posted by sir2
it was on a dynojet
And you made 401 before on the same dyno? I did 435 uncorrected on a dynojet with my XFSC.
Old Nov 5, 2012 | 02:14 PM
sir2's Avatar
How much tourqe did you make?
Old Nov 5, 2012 | 02:32 PM
BigCat09's Avatar
Remember, the actual numbers are not what you are looking for but rather what it was from stock to after the flash to see what worked as a % increase.
Things like calibration, air temp, elevation,fuel, etc all play a part in the top number so base your opinion on the % increase seen.
Old Nov 5, 2012 | 03:41 PM
I wish I knew, it didn't measure torque and I had to ask to have the a/f recorded. I might do the pulley and flash BigCat has I would dyno again then. The car makes more power then it can use already...need a traction solution first then add power.
Bigcat, true 401-420 hp with a flash is a nice gain! 20 hp probably feels like 100 on the buttdyno.
