DRL problem
Old May 14, 2019 | 07:29 PM
Disco73's Avatar
Default DRL problem
Ok so I've had my xf 2.2 luxury for 3 days now and I've just noticed the left side DRL doesn't turn off at all! Stalk is in the off possession car is turned off and locked and it still stays on.. it doesn't turn off even after leaving it for a few hours it's still on! I've tried disconnecting the battery to no avail. If it was the stalk then I would assume both left and right DRL would stay lit but it's only the left DRL.. does anyone else have this problem or know what's causing it?
Old May 16, 2019 | 10:51 AM
elrich75's Avatar
Default same...
same problem but it resolved itself.
mine was due to heavy rainfall and the insides got wet
mine weren't turning on or off or one would, one wont, the side yellow marker light wouldn't turn off and my signal lights were acting up as if they went out..
i parked a couple days in the texas sun and eventually it dried off and everything working fine... weird
hopefully it resolves itself as well because i have no idea
Old May 16, 2019 | 11:16 AM
Gus's Avatar
Gus
What year is your car?
Gus
JagRepair.com - Jaguar Repair Information Resource
Old May 16, 2019 | 03:04 PM
Disco73's Avatar
2013 2.2 luxury
Old May 21, 2019 | 01:57 PM
Disco73's Avatar
Has anyone else had this problem?
Old May 22, 2019 | 01:25 AM
John Williams's Avatar
There's a lot of information about the washer pump leaking & the water wicks down the loom to the fusebox at the bottom of the offside A piller (uk). This corrodes the terminals in the box & throws up all sorts of problems. You can pull the top left multiplug out of the front of the fusebox & check the connectotrs in the plug & fusebox.
jonesy
Jun 8, 2014 06:32 PM
RSVG
Oct 24, 2010 04:33 PM
Adam Lueb
Sep 12, 2010 01:22 PM
JimC64
Non-Jaguar Vehicles
Aug 6, 2010 08:15 PM
v8stype
Feb 8, 2009 11:32 AM
