Ok so I've had my xf 2.2 luxury for 3 days now and I've just noticed the left side DRL doesn't turn off at all! Stalk is in the off possession car is turned off and locked and it still stays on.. it doesn't turn off even after leaving it for a few hours it's still on! I've tried disconnecting the battery to no avail. If it was the stalk then I would assume both left and right DRL would stay lit but it's only the left DRL.. does anyone else have this problem or know what's causing it?
same problem but it resolved itself.
mine was due to heavy rainfall and the insides got wet
mine weren't turning on or off or one would, one wont, the side yellow marker light wouldn't turn off and my signal lights were acting up as if they went out..
i parked a couple days in the texas sun and eventually it dried off and everything working fine... weird
hopefully it resolves itself as well because i have no idea
There's a lot of information about the washer pump leaking & the water wicks down the loom to the fusebox at the bottom of the offside A piller (uk). This corrodes the terminals in the box & throws up all sorts of problems. You can pull the top left multiplug out of the front of the fusebox & check the connectotrs in the plug & fusebox.
