Engine Code P0627 on XF 2011
Old Feb 27, 2018 | 10:09 AM
timdmoss's Avatar
Default Engine Code P0627 on XF 2011
Hello Jag community. needing some help. Im receiving P0627 code (fuel pump circuit open) the car will sometimes not start, and will sometime fall dead while driving. I replaced fuel pump with OEM part April '17. Can anyone tell me what this problem is? Thanks.
Old Feb 27, 2018 | 12:46 PM
JagV8's Avatar
https://www.jaguarforums.com/forum/x...7480-new-post/
Old Oct 18, 2019 | 09:33 AM
Cojag's Avatar
Did you ever solve the issue? I'm having the same problem. I replaced the fuel pump now I have that same code. Car starts and seem to run fine but the engine light stays on
Old Oct 18, 2019 | 10:20 AM
lotusespritse's Avatar
May not be the problem, but check the connections on the fuel filter on top of the fuel tank. They are known to cause problems. If you have the original fuel filter, time to replace it anyway. There was even a recall, so you could get it done for free. The filter has electrical connections going through the body that can corrode at the connectors.
timdmoss
XF (X260)
Oct 18, 2019 09:36 AM
AttyDallas
May 21, 2018 05:52 PM
Ruben1
Jul 15, 2016 03:50 PM
62sunbeam
Oct 6, 2013 10:08 PM
jaguarlady03
Jan 19, 2013 11:41 AM
