everything shuts off
Old Jul 20, 2021 | 12:06 PM
newbietojag's Avatar
Default everything shuts off
I'm new to Jaguars. In the past I've only had BMW's. I found a great deal (or so I thought) on a 2009 Jaguar XF. The car has been amazing until recently. This morning I drove to work and when I left for lunch, the car was completely dead. It wouldn't start and no electronics would come on. I tried to jump it off and nothing would happen. I replaced the battery and still, nothing. The car is completely dead. Any advice?
Old Jul 20, 2021 | 01:24 PM
chris.schneider's Avatar
Could be a blown main fuse, found next to the main battery. Did you check them?
Chris
Old Jul 20, 2021 | 03:02 PM
I haven't . Where is it located?
Now that I think about it, this has happened once before. I used a battery charger and after about an hour, it fired right up. That was about out 6 weeks ago and now I'm having the same issue.
Old Jul 20, 2021 | 07:13 PM
BritCars's Avatar
Is the battery dead (check with a volt meter) or car unresponsive? Maybe something drained the battery. Maybe a short somewhere. Or poor earthing. Start by determining if you have power to the car at all from the battery.
Old Jul 20, 2021 | 08:58 PM
My first thought was the battery. It was a little low and I did replace it. It didn't work. Same issue.
I have it hooked up to a charger as that is what I did previously. As soon as I hooked it up, the lights on the inside came on but nothing else works, windows won't roll up, doors won't lock but the headlights came on and will not shut off. The taillights did not come on. Im stumped.
Old Jul 21, 2021 | 02:10 AM
The main fuse is probably good if your interior lights are coming on whilst the car charger is connected .
A corroded ground point could cause issues like this. Try to undo, spray and redo the chassis ground point just next to the battery.
Using a voltmeter would be most useful to measure the voltage on the battery, and to test if you get something on the junction boxes. A fully charged battery will read something between 12.6 and 12.8V, more if it just off the charger. 12.4-12.6V is ok for a battery that comes out of storage. Between 12.1 and 12.4 indicates a partially discharged battery, might still be able to crank but can cause electronic issues. These values can vary depending on load and temperature, but it gives you an idea.
Chris
Old Jul 21, 2021 | 08:24 AM
This morning I checked on the car. It started like there was no issue. I did notice that the passenger side floor was wet. Could this be an AC drain line is clogged and is shorting out the electronics?
Old Jul 21, 2021 | 06:03 PM
BritCars's Avatar
Roof drain can become clogged and get the pax carpet wet. Note there are several impt modules under there which will corrode and get ruined so you should lift up the carpet to dry it and check underneath. Bluetooth module, Sirius, TPMS etc
Sounds like you have an earth shorting issue somewhere which is putting a high draw on the battery when wet and draining it.
Old Jul 22, 2021 | 11:12 AM
gumby7734's Avatar
I had the battery draining issue with one of the modules, when the roof drain clogged and i found the pool of water under the carpet.
QueenSuga
Oct 27, 2021 03:15 AM
jaguarXFsupercharged_XFR 500HPclone
Mar 7, 2019 10:06 AM
rlentini
Dec 10, 2014 11:16 PM
anuprn
Oct 21, 2014 11:24 AM
srmtn
Jan 19, 2009 07:45 PM
