Fan continuously runs
Old Nov 4, 2016 | 06:37 AM
ednoon's Avatar
Default Fan continuously runs
I have a 2010 XF that I recently installed a new thermostat on. Now when I'm driving and come to a stop the fan runs continuously. When I shut the engine off the fan stops
Old Nov 4, 2016 | 10:43 AM
lotusespritse's Avatar
When you say you recently installed, do you mean you personally worked on the car, or you personally paid someone to install it? Lots of people are very lose with that phrase.
If you did it, did you make sure you reconnected all of the electrical connectors? Its possible you bought a faulty replacement part.
Old Nov 4, 2016 | 12:08 PM
ednoon's Avatar
I paid to have it installed.
Old Nov 4, 2016 | 12:13 PM
Then take it back and tell them to fix it.
Old Nov 11, 2016 | 11:42 AM
davetibbs's Avatar
On previous cars I've owned, this can be caused by disconnecting the coolant temperature sensor - if the ECU sees no output (or a strange output) from the coolant temperature sensor, it will run the fans continuously as a fail-safe.
As lotusespritse says, it's likely an electrical connector at fault, but the installer should sort it. Hopefully just a case of plugging a connector back on.
Old Apr 4, 2021 | 10:02 PM
kg74's Avatar
Just found this - maybe it will help.
http://jagrepair.com/images/Electric...al%20Guide.pdf
Old Apr 5, 2021 | 09:23 AM
clubairth1's Avatar
Community Influencer
That repair guide says it's for the 2005 and up XJ?
Pretty different cat? He has an 2010 XF.
Old Apr 6, 2021 | 07:25 PM
BritCars's Avatar
He also posted nearly 5 years ago. So I would hope he has sorted it now!!
Old Apr 7, 2021 | 11:09 AM
clubairth1's Avatar
For sure!
Enrique Meza
Jul 24, 2023 06:46 PM
Kmalpatel
Feb 11, 2021 11:46 AM
Dukejag
Oct 23, 2018 01:54 PM
Rhett
Oct 23, 2015 03:25 AM
Terry
Apr 29, 2012 08:54 AM
