Fuel filler door defect, again.
Old Jul 31, 2012 | 07:14 PM
jagular's Avatar
Default Fuel filler door defect, again.
Anyone have their fuel filler door refuse to open repeatedly even after the so called factory fix has been applied?
Mine worked fine before the updated mechanism was installed and now doesn't fit properly and doesn't work properly.
Old Jul 31, 2012 | 11:10 PM
miamijag's Avatar
Spray it with the w40. Will work as a dream
Old Aug 1, 2012 | 02:01 AM
chuckh007's Avatar
And make sure that it is un-locked before trying to open it !!
Old Aug 1, 2012 | 07:48 AM
Blackcoog's Avatar
Yup, it needs lube. The rubber gasket on the cap appears to dry out and stick. I brought it in to the dealer and they said it's pretty common.
Old Aug 1, 2012 | 06:32 PM
jagular's Avatar
My dealer mechanic says the design is not good. He adjusted the mechanism and it seems to work now, fingers crossed.
He recommended against replacing the part, suggesting the new ones are also faulty in the same way.
He also suggested that there is an anti tamper function. If more than five consecutive unsuccessful attempts are made in a row with the flap refusing to open then an ignition sequence is required to re-activate the mechanism. It seems it is electrically operated even though triggered by a push on the door itself.
Applying silicone type lube to both sides of the catch and silicone based rubber cleaner to the rubber/ plastic surround failed to improve the operation.
dsnyder586
Dec 29, 2024 07:39 PM
1100me
Jul 24, 2023 06:10 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
mrplow58
Sep 9, 2015 11:27 AM
AL NZ
Sep 4, 2015 08:39 PM
