Head unit
Old May 14, 2018 | 01:32 AM
Ki4low23's Avatar
Default Head unit
Has anyone upgrade to a new radio in thier XF.
Old May 17, 2018 | 10:56 AM
Dare's Avatar
What sort of an upgrade are you aiming for? 1 cd to 6 cd? In any case swapping it out is simple, but you will need a shop to program it for you in order for it to work and your car to know what's going on. Used units are easy to find online, but be aware there are "quite" a few out there and they only work on specific MY cars. If you're looking to upgrade the audio system, for instance base audio to premium you'll be looking at new speakers, amp, wiring etc. and quite a bit of labour. If that's your aim you'll be able to find topics on the subject within this forum through the search.
Old May 20, 2018 | 03:28 PM
Ki4low23's Avatar
Default Head unit
was looking to replace the stock head unit with a aftermarket radio if this is possible.
Old May 23, 2018 | 03:40 PM
Dare's Avatar
Can’t help you with that, it’s very much integrated into all your controls over climate etc., so you’d have to find an aftermarket one that integrates to the MOST system. Don’t think there’s a big enough market for that.
Old May 23, 2018 | 09:48 PM
Ki4low23's Avatar
Default Head unit
Dam wish I knew someone who try doing it.
Old May 24, 2018 | 10:42 AM
jfire's Avatar
How did you upgrade to integrated Bluetooth?
Old May 30, 2018 | 01:28 AM
Dare's Avatar
With a bit of a workaround. I hardwired a bluetooth receiver undernearth the centre console, connected directly to the aux and 12v socket wiring. It powers up whem the car does, connects automatically to my device and works when I select aux as input.
Might sound sloppy, but in fact, compared to a factory system like we have in the LR D4 the only nag I have is not being able to change tracks from the steering wheel. There are two ways to fix that:
1. Go lazy, and buy a bluetooth audio-control-button-thingy, and mount it somewhere. Preferably up front, not in the trunk. Pretty useless there.
2. Go full on nerdgasm, and use the internals of the aforementioned audio-control-thingy to connect up to the signals sent from the steering wheel buttons. It could be done, not saying it’s easy.
Could you get also the song info on the display some way? Short answer is no. Long answer would be perhaps, if you’re a tech god with superior coding abilities and too much time. I don’t know how.
Old May 30, 2018 | 04:00 AM
jfire's Avatar
I've gone down the route of a Bluetooth receiver which I've plugged in to the cubby box aux audio input and 12v, which has a remote control wired in, which I've run slightly lazily round the side of the cubby box and out the top but tucked round the silver fascia panel so I can stick the controls in front on the arm rest for convenience with minimal wires showing. Not being massively comfortably with electrics, or taking the interior apart, I'm happy with this £8 solution! One annoyance however is I can't get Google Assistant to take voice commands through the Bluetooth, which is a completely separate issue.
Old May 30, 2018 | 04:05 AM
wardo5757's Avatar
For Bluetooth get the Bovee, plugs into the port in the center console and their available on Amazon, it automatically connects to your iPhone or android and you can change tracks with your controls.
Amazon Amazon
Old May 30, 2018 | 04:21 AM
Cambo's Avatar
Yeah, Bovee works fine.
Digitron
Dec 23, 2017 10:50 AM
greverrr
Apr 24, 2013 03:45 AM
Jan 3, 2012 12:52 PM
anoojra
Jan 30, 2010 06:01 AM
Feb 5, 2007 12:44 PM
