Hood closed put info system states open - Can't lock car
Old Aug 10, 2013 | 06:12 PM
10 XF Premium's Avatar
Default Hood closed put info system states open - Can't lock car
My car is starting to irritate me.
Within the last 5 days I have been dealing with several annoying electrical faults.
It started with the TPMS really going nuts. Continual sensors going off, all tires, one after the other. And then resetting and starting all over again.
Then the Climate System just grayed out and I could only use the AUTO button and the on/off fan speed dial to control the system. The display was completely grayed out, even the outside temp display was missing. After cycling power a few times that finally started working again.
Now, this afternoon, the info system tells me the hood is open and now won't let me lock the car. I drove it to several places this morning and it was fine. Park in the garage for 3 hours and now it is saying the hood is open.
I have opened and closed the hood several times, made sure nothing is interfering with the latches or hinges but still saying it is open.
Where do I look now?
The dealer is 100 miles away and I can't drive the car anywhere and leave it due to being unlocked.
Anybody know where to look or how to fool it until I can get it to the dealer?
Old Aug 10, 2013 | 07:58 PM
ONEsicJAG's Avatar
Check The Battery?
Old Aug 10, 2013 | 08:10 PM
DPK's Avatar
DPK
DITTO on the battery;
Jags act flaky when the batter is going bad..
Old Aug 10, 2013 | 08:40 PM
Battery was replaced less than 6 mo ago, but I will check.
Old Aug 11, 2013 | 12:35 AM
Battery is good.
After looking real close, the bonnet alarm switch is under the driver side latch (on US model cars anyway).
There is a curved spring metal arm that is pressed down by the hood catch when closed. When pressed down it tells the alarm system the hood is closed.
The curved metal arm on mine is collapsed and when the hood is closed it is not pressing down on the curved metal arm enough to give a "closed" signal.
I used a pair of picks, one straight and one curved and held the bottom of the curved arm with the straight pick and used the hooked pick to pull up on the top of the curved metal arm to make the curve wider so the hood latch can press down on the alarm switch more.
As of right now, it is working.
Old Aug 11, 2013 | 12:46 AM
ONEsicJAG's Avatar
Originally Posted by 10 XF Premium
Battery is good.
Seems Odd It Would fail Being Only Three Years Old. Glad It Was Something Simple. Fingers Crossed That's The Fix. Now I Wonder What Has Caused All The Other Glitches?
Old Aug 11, 2013 | 09:59 AM
jagular's Avatar
TPMS faulting is very common. Unless recoding at the dealer fixes this I'm afraid the central module is likely faulty.
The hood position sensor problem is likely some grease monkey bending it.
The LCD screen unfortunately may also be faulty and that's pricey to replace.
All this should still be under warranty.
Old Aug 11, 2013 | 03:39 PM
ONEsicJAG's Avatar
Thanks For Posting This For The OP ....I Know Very Little About This MY ..But I'm Trying To Help Everyone And Anyone On This Forum. I Get All The Help I Need, So I Want To Help Anyway I Can.
Old Aug 11, 2013 | 05:00 PM
xfdave's Avatar
I have a 2012 and am on my second hood switch replacement. It seems to be a known issue.
Old Dec 16, 2014 | 09:59 AM
PatroneyXFR's Avatar
I seem to be having the same issue , Any idea of the hood switch location and is it something i can do on my own?
BrentGardner
29
Dec 16, 2024 12:13 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
msdg137
Sep 16, 2015 06:24 AM
Tony Bow
Aug 28, 2015 05:17 AM
Andrew McVey
16
Aug 27, 2015 07:21 PM
