issues issues issues smh
Old Dec 28, 2016 | 02:06 PM
digimurda's Avatar
Default issues issues issues smh
hi all.
2009 XF
anyone have an issue when coming to a complete stop and car seems the surge forward kind of like if it was a bad motor mount or the engine bounces or something?
I also have a strange howling noise coming from the passenger side floor area specially on cold starts.
and last but not least is there any possible way that my parking assist might not be working because of the sensor behind the brake peddle?
im new to this and did some research on here but found no answers.
thanks
Old Dec 29, 2016 | 01:34 AM
JagV8's Avatar
Might be a "lurch" - see previous threads - and can often be fixed e.g. by reprogramming / fluid change.
Old Dec 29, 2016 | 04:57 PM
digimurda's Avatar
Has anyone experienced the howling noise coming from the front passenger side area
Old Dec 29, 2016 | 06:24 PM
bmcinsd's Avatar
I seem to be going through the same issue on cold starts in the morning (hear a humming for the first few minutes). Sounds transmission fluid related. I will probably replace the tranny fluid and pan filter. Mine lurches when I place it into park. I generally put on the parking brake before taking my foot off the brake pedal. If I don't put the parking brake on before letting off the brake pedal, the car will jump a few inches.
Old Dec 29, 2016 | 08:18 PM
digimurda's Avatar
I dont think the humming is transmission related as when i have the car runing and accelarate it the noice goes with the accelaration
Old Dec 30, 2016 | 02:17 PM
jagwower's Avatar
possibly a wheel bearing
Old Jan 1, 2017 | 01:04 PM
digimurda's Avatar
Its not when the car is driving
Old Feb 11, 2021 | 03:28 PM
BudL1te's Avatar
if the car is still and you accelerate the engine speed and hear the noise increase then it is likely an accessory or pulley or even the belt that could be causing the sound.
If it is while the vehicle is moving the it could be the above still or wheel bearing or CV joint.
If a manual transmission, the throw out bearing can also make noises.
Old Feb 11, 2021 | 03:30 PM
BudL1te's Avatar
Next time you come to a stop, use your left foot on the brake, not the right foot, and see if you still get the lurch.
Old Feb 11, 2021 | 08:44 PM
Oxidizer2k's Avatar
Had the same issue, did a drain and fill, and drove it. No adaptation. After a couple of driving cycles, my issue went away. Transmission is very smooth now.
not sure if you’re experiencing the same thing.
Old Feb 12, 2021 | 08:03 AM
Gus's Avatar
Gus
Read the OBDII codes and post the codes.
Gus
JagRepair.com - Jaguar Repair Information Resource
AltsXJ8
Oct 1, 2025 11:24 PM
mrmike
Aug 1, 2020 05:28 PM
Torino
Canada
Jan 9, 2020 09:56 AM
sayhitobaldy
Sep 19, 2018 06:54 AM
andrew2110
Oct 4, 2014 11:53 AM
