Jaguar wheel offset
Old Mar 31, 2014 | 01:20 PM
pharmer's Avatar
Default Jaguar wheel offset
Gents,
I have a 2013 XF with 19" Artura OEM wheels. I'm considering new rims and don't wish to make a mistake with the fitment. Can anyone tell me the full specs on these factory wheels? This is what I'd like to know...
Size: 19" X 8.5"
Lugs = 5 X 108mm
Center Bore = ?
Offset = ?
Thanks in advance!
Best wishes,
Chris
Old Mar 31, 2014 | 01:54 PM
Executive's Avatar
The offset is 49mm.
And, i believe the bore is 63.4mm.
If you are purchasing aftermarket wheels, most usually have larger bore anyway. If that's the case, you can purchase rings.
Old Mar 31, 2014 | 02:24 PM
pharmer's Avatar
Thank you! Those are the #s I've been coming up with but have not been able to verify.
Considering this wheel in Titanium finish:
ACE CONVEX WHEEL - D704 WHEELS for BMW WHEEL, NISSAN Z INIFINITE G RIMS, MERCEDES E S C Class WHEELS, CONCAVE WHEELS, custom wheels, stagger wheels, Range Rover
Ace Alloy is suggesting a 40mm offset which will move the tires out slightly.
Also considering caliper covers from MGP - anyone have feedback on these?
Thanks again,
Chris
Old Mar 31, 2014 | 02:32 PM
Executive's Avatar
You will be fine with the 40mm offset.
Those caliper covers are just going to heat up your brakes faster and cool slower. I would just replace the spring loaded caliper covers with ones that says JAGUAR, if you don't already have that.
Old Apr 1, 2014 | 08:30 AM
pharmer's Avatar
Thanks for the feedback. Not sure that my calipers have existing covers that can be replaced. Here is a file photo of what mine look like:
2013 Jaguar XF 2 0T Wheel 10 Photo #340352 - Automobile Magazine
They appear as unfinished steal. May I ask what caliper covers you're referencing and where I might purchase a set?
Thanks again,
Chris
Old Apr 1, 2014 | 08:48 AM
Executive's Avatar
Not a problem.
Yes, the little brake pad covers (rectangular piece) can can be replaced. It's quite easy, once you remove the wheels, should take no more than 2 minutes each. Just have to be careful getting them off and putting them back on as they are spring loaded. See in the picture.
You can get them at any Jaguar dealer on even online. I can't imagine them being too expensive.
This is what your looks like.....
This is what the one that says JAGUAR on it looks like....
Attached Thumbnails Jaguar wheel offset-edobernig-107535-albums-xf-sc-brakes-6097-picture-front-caliper-16016.jpg   Jaguar wheel offset-07.jpg   Jaguar wheel offset-jaguar-f-type_v8_s_2014_800x600_wallpaper_ca.jpg
Old Apr 1, 2014 | 09:17 AM
pharmer's Avatar
Thanks - that's great and definitely the right way to go.
I've run a quick search on the web but don't find the plates for sale. Will contact the parts department at my local dealer...
Thanks again,
Chris
Old Apr 1, 2014 | 09:22 AM
Executive's Avatar
No problem Chris, glad to be of help.
Keep us posted on what you find.
You can also try these guys, might sell them cheaper.
2012 Parts - Direct JPLV Porsche Parts.com
Jaguar Parts - Jaguar Parts Center - Call (800) 510-1401 for Genuine Jaguar Parts and Accessories
Old Apr 1, 2014 | 03:05 PM
pharmer's Avatar
I called these places but no one seems to know anything about the caliper covers. I also called into my local Jag parts department - they had no idea, but I sent them an email with some pics - I don't suspect they'll come back to me though. If anyone has ideas where to find these covers already painted with the Jag name, I'd appreciate hearing from you...
Cheers,
Chris
Old Apr 1, 2014 | 04:05 PM
duke_dallas's Avatar
Others have used "Jaguar" caliper stickers that are available on ebay with good results. RodTee XF for example - Jaguar Forums - Jaguar Enthusiasts Forum - RodTee XF's Album: Porcelain Goddess - Picture
Old Apr 1, 2014 | 04:07 PM
Executive's Avatar
Chris,
They are called Anti Rattle Clips or Caliper Retainers, hopefully that helps.
You may be in luck, i have found on ebay but it's for the XFR. New Genuine Jaguar XJ XF XK R Caliper Mount Retainer Clip C2S33408 | eBay
Maybe you can give the part number in the listings and dealer should trace it back for you.
Old Apr 1, 2014 | 07:13 PM
pharmer's Avatar
Thanks guys, that's really helpful! When I asked my local Jag dealer, they did some research but came up empty - advising me...
"Checking around now I don’t see anything in my jaguar catalog. Do you know if this is an accessory or an aftermarket piece that isn’t jaguar. Give me a little time and See what I can come up with."
I'll share the info provided and hopefully it will point them in the right direction. If not, I'll certainly consider going the decal route.
Thanks again,
Chris
Old Apr 4, 2014 | 03:47 PM
jleuz1's Avatar
Originally Posted by pharmer
Gents,
Size: 19" X 8.5"
Lugs = 5 X 108mm
Center Bore = ?
Offset = ?
Thanks in advance!
Best wishes,
Chris
If you pull off your wheels the offset and width are stamped inside the wheels.
tonimccloud
19
Jan 18, 2020 01:56 PM
Griffbritgreen
Jul 27, 2016 05:43 AM
Johncy2000
Dec 15, 2015 08:02 PM
duprey26
Sep 8, 2015 05:28 PM
plums
Aug 31, 2015 06:55 PM
