Jaguar XF air vent Problem
Old Mar 16, 2020 | 10:43 PM
Kurt Iseli Jr.'s Avatar
Default Jaguar XF air vent Problem
Hello my name is Kurt. And life in spain. I will thank everyone that can help me. And im happy to be here in this forum. So i want to explain my problem, and sorry my english is not perfekt. My car is a Jaguar XF 2.7d and my problem is with the ventilation. They don't work like they need. Sometimes they works perfect but very less so like every 2-3 months is working everyting but only for 2-3 hours. and then is the problem the 4 ventilations are open all the time, i can change the temperature on the display but the air temperature is not chaning. i can change it on the display where i want that come the air. But the air come only on the feet. Can somebody help me what that can be?
thanks a lot for your help
Old Mar 17, 2020 | 04:08 AM
fivel's Avatar
Does it only circulate air over your feet no matter what setting you select on the display?
For example, if you turn off "auto" climate control, select the front vents and turn the fan on full, does it still just come through the lower vents by your feet?
With regards to the temperature, are you trying to heat or cool the air?
Have you tried reading any error codes from the OBDII interface?
I'm going to try this in Spanish too (or rather I'm going to see if I can word it sensibly so that google translate can make sense of it)
¿Solo circula aire sobre sus pies sin importar la configuración que seleccione en la pantalla?
Por ejemplo, si apaga el control de clima "automático", selecciona los respiraderos delanteros y enciende el ventilador por completo, ¿sigue entrando por los respiraderos inferiores a sus pies?
Con respecto a la temperatura, ¿estás tratando de calentar o enfriar el aire?
¿Has intentado leer algún código de error de la interfaz OBDII?
Old Mar 17, 2020 | 04:32 AM
Yes i can change what i want and the air will come only by the feet. The Auto climate i put everytime off but still not work. Yes sorry that i have forget the air power i can change but this is the only thing. Yes but still the aire is only at the feet. And to when i stop the engine the vents not close. So they are everytime open. But how i have say sometimes work everything perfekt but only for a shorttime. Yes i was in a official Jaguar Garage and they tell me that they can not say without trying change parts. And when is not this i need tu buy it. so this is to much risiko. The only thing what i have change is control unit in the footwell on the passenger side. ( but i have buy a used one in ebay)
Old Mar 17, 2020 | 07:27 AM
fivel's Avatar
Are the face vents configured to close when the car is turned off from the information system?
Old Mar 17, 2020 | 08:30 AM
yes in the system is that they open and close
but i have now read with OBDII
and i have this Fault
- B1088 LIN bus B
- B11ED Electric heater control module
- B11F8 outer air vent left
- B11F9 inner air vent left
- B11FA inner air vent Right
- B11FB outer air vent Right
can somebody tell me what is LIN bus B ? Many time when i clean the car with Water sometimes is working everything
Old Mar 17, 2020 | 09:37 AM
fivel's Avatar
That'll probably be it. It looks like you have a wiring or earth fault with the climate control unit. Could be a loose or corroded connection.
Old Mar 17, 2020 | 09:42 AM
yes i think the same. I think is something with earth because sometimes when i clean it with water. Works it for shorttime. But i will check al conections thank you for help
Old Mar 17, 2020 | 10:05 AM
fivel's Avatar
The "registers" are the air vents.
You seem to have a fault to the registers and the air distribution. I'd check the power in to the control unit is ok (LIN_POWER_2), the GND and the signal distribution to the air vents. It might be you have two faults, both with the vents and the air distribution motor.
Failing that it could be a faulty module but that seems odd if you can control the fans.
Old Mar 17, 2020 | 10:18 AM
exactly now when i go in the car close the door everything is working. Then 1 min later in the middle the right vent is not working. I have make a video. Yes the only thing what i can change is the air power so than come more or less air. On the display i can change everything. But the signal is not coming to the vents or air distribution motor. I will check now the power and the cabel and when know something more i will share it here in the forum.
And now is working other Time nothing.
Old Mar 17, 2020 | 10:39 AM
fivel's Avatar
These links might be useful
Workshop manual:
https://www.dropbox.com/s/itzjq6rti2...anual.pdf?dl=0
Wiring diagram:
http://www.jagrepair.com/images/Elec...20X250Comp.pdf
Old Mar 17, 2020 | 10:42 AM
thanks for the Link but both not working. I will now take out the 4 vents and check the power and the conection
Old Mar 17, 2020 | 10:58 AM
fivel's Avatar
Sorry, that was my cut and pasting error
Workshop manual:
Wiring diagram:
Old Mar 17, 2020 | 11:38 AM
No problem thank you
Old Mar 17, 2020 | 11:47 AM
Workshop manual:
Wiring diagram:
now i have more DTC
i can not explain this.
i have not start the work jet but more faults.
and the seat clima have to an error now.
i can delet all DTC only the electric heater control modul i can not delet.
Old Mar 17, 2020 | 05:38 PM
fivel's Avatar
The could still be an electrical problem, from the wiring diagram is seems that both the instrument cluster and the climate control system use the same ground, behind the instrument cluster on the right hand side of the "IP beam". Perhaps there's some damage to the loom or the grounding connections, or just a bad connection somewhere in there. Unplug it all and clean the contacts/connections?
Old Apr 6, 2020 | 11:04 AM
witch one is the Electric heater control modul?
i have check all the cabels and find nothing.
Is this the electric heater control modul?
Old Apr 6, 2020 | 03:52 PM
User 42324's Avatar
The aux heater can start failing & it starts spiking the can-bus system. Blowing cold air at your feet no matter what the controls say is a symptom, along with odd vent behaviour. The easy way is disconnect the heater.
Old Apr 6, 2020 | 04:27 PM
unplug the heater? Or what you mean ?
Old Apr 6, 2020 | 04:45 PM
you mean unplug the 3 or 8
Old Apr 7, 2020 | 10:06 AM
User 42324's Avatar
Neither. You want to disconnect the auxiliary electric heater. On my 2009 XF 3.0 diesel, at the heater, a small green/white wire goes to it. Disconnect that. Your wiring may be a different colour. If this works, go to your garage & get them to program it out too.
I downloaded both the files above but couldn't open them & I can't find a decent diagram for you as I'm doing this on my phone. The S-type had a diesel powered Webasto auxiliary heater. With the XF range they changed to an electric one. It's purpose is to help heat up the coolant quicker in cold weather, so the engine & heating warms up quicker. Do a Google search for 'Jaguar XF auxiliary electric heater' or ask your garage. Mine was easy to get to, but I have a different model.
