Location of the Transmission Control Module on 2008 Jaguar xf x250
Old Apr 20, 2021 | 06:25 PM
Olusjag's Avatar
Default Location of the Transmission Control Module on 2008 Jaguar xf x250
Can anyone please advise me on the location of the Transmission Control Module on 2008 Jaguar xf x250 2.7d?
Your help will be highly appreciated
David
Old Apr 20, 2021 | 07:20 PM
JBzXJ40's Avatar
The Transmission Control Module and Valve Body are one unit, inside the transmission
Old Apr 20, 2021 | 07:27 PM
Olusjag's Avatar
Thanks so much
​​​​​​This is definitely a job meant for professional
David
Old Apr 21, 2021 | 04:19 AM
Olusjag's Avatar
Thanks again for your time but just been to Jaguar breakers and they showed me the Jaguar xf x250 2.7d gear box and told me the TCM is as attached and that it is not inside the gearbox.
Confused now, not knowing what to do.
David
Old Apr 21, 2021 | 08:01 AM
Six Rotors's Avatar
I think there is terminology confusion here. The piece in your pic above is the transmission shift control module, or as it shown in the EPC----module- transmission, shift control.
So it really depends on what problem you are trying to solve as to what part you need. You have not really described the problem.
Old Apr 21, 2021 | 02:24 PM
Olusjag's Avatar
Below is copied from (earlier post in different thread) what I would say lead me to searching for the location of the TCM
My beloved 2008 XF 2.7 sometimes goes into what i will describe like a gear slip. When accelerating between 50 to 55mph moving up, the rpm will suddenly jump from say from1600/1700 to 3000 and Gear Fault displays on the dash. The car immediately loses power or acceleration from that moment until i stop the car and clear the Gear Fault with a scanner and only then will i be able to drive the car normally again until it happens again. Or sometimes when i try to accelerate fast, like move from say 40/45 to 60/65 in seconds. I must say this hardly happen when am driving within Nottingham but definitely when on a fair distant trip. The fault code it always comes up with before clearing is P0814, any idea what this problem is and how can it be resolved Thank you David
Old Apr 21, 2021 | 05:04 PM
Fraser Mitchell's Avatar
Definitely sounds like a fault inside the gearbox. Shifting is controlled by valves in the mechatronic unit and failures can occur with these, one fault being leakage from the seal clamping the unit together. How many miles on the car ? It is possible a reflash of the TCM firmware will solve the problem but you'll only find out if you do it. Have you taken the car to an autotransmission specialist ? The autotransmission was made by ZF and used in many makes of European car, not just Jaguar.
Old Apr 21, 2021 | 05:31 PM
Six Rotors's Avatar
OK. We do not have diesel XFs like yours here in Canada. I did take a look at the 2009XF Workshop Manual which you could download from the stickies section of this Forum. The manual shows DTC P0814-01 and suggests it likely to be an electrical gremlin in the "Transmission Shift Module or TSM" (which is the part you have pictured above). Specifically it mentions LED failure in the PRNDS display. So I would expect you may see the red lights go out!!
I have no experience with the TSM so I cannot offer any other suggestions. There are other threads you can check on this forum.
Old Apr 21, 2021 | 05:51 PM
Olusjag's Avatar
Thanks FraserThe milage on the car is 79437 and no I haven't taken it to an autotransmission specialist
David
Old Apr 21, 2021 | 06:47 PM
Olusjag's Avatar
Six
The person who sent me the pictures you referred said the electronic board underneath the shifter is the culprit and yes the red heartbeat light sometimes goes off
David
Old Apr 21, 2021 | 11:09 PM
JBzXJ40's Avatar
Your picture is the Gearshift Module - and yes these gave problems, the main one being that it doesnt rise when starting the car
The issue you're describing would be with the transmission itself. As mentioned, there could be some software to update, however with age the valve body/Transmission Control Module do give problems.
Old Apr 22, 2021 | 02:14 AM
Olusjag's Avatar
JBzXJ40
Thanks. Can you please confirm the location of the TCM or how to find the workshop manual for xf x250
David
Old Apr 22, 2021 | 03:21 AM
JagV8's Avatar
The TCM is inside the autobox.
Old Apr 22, 2021 | 07:37 AM
Six Rotors's Avatar
Workshop Manual-----go to the top section of this XF Forum and find the sticky Handbook download, go to the last post on p2 by Jssaab and follow the instructions.
BSG-meyana
Jun 12, 2022 10:08 PM
Rene Anderson Sr.
General Tech Help
Sep 4, 2020 04:38 AM
Jellybellyjames
Jul 10, 2017 02:10 PM
Gareth Bradshaw
May 25, 2017 11:44 AM
dapol
Nov 2, 2013 12:46 PM
