Lock OUT of my car w/ my keys
Old Dec 17, 2024 | 03:42 PM
luvmyhips817's Avatar
Default Lock OUT of my car w/ my keys
2010 Jaguar XFR Supercharged
My car is locking me out.
It will not read my key, while it in my hand. When I push the button to unlock the door it will not unlock or lock, none of the buttons work when it's doing this. Eventually, I am able to get the door unlocked. Then when I get in to start the car, it says "no smart key found." When I unhook the car battery and plug it back up I am able to open the door and start the car.
Does anyone know why what this could be?
I have gone to different shops, and they say, it's my key. But if I buy another key and it continues to keep happening, I would have spent over seven hundred dollars for a key for nothing.
Ps. NEW BATTERY IN THE FOB.
HELP!!!!
Last edited by luvmyhips817; Dec 18, 2024 at 10:29 AM. Reason: Add Yr, make of my car
Old Dec 17, 2024 | 03:54 PM
NBCat's Avatar
Has anyone thought to replace the battery in the smart-key fob?
Old Dec 17, 2024 | 09:28 PM
Default Common sense
That was the first thing I did. I wouldn't be asking for assistance if I hadn't tried the basics.
Old Dec 17, 2024 | 10:00 PM
vfrman's Avatar
Could be an issue with the KVM module. If you have the SDD software you can try to run the Security-Immobilization program. This will re-program several modules and may fix the issue.
Old Dec 18, 2024 | 08:47 AM
thistle4celtic1's Avatar
Does your spare key work as it should?
Might also help if you post the model year of your XF
Old Dec 18, 2024 | 10:39 AM
HELP!!!!
ok, I add that to the post. Thank you.
Old Dec 18, 2024 | 12:13 PM
Take a look at this thread.
It might offer some insight. There's some info there on how I made two spare keys/fobs for much less than the dealer wanted.
Old Dec 24, 2024 | 09:43 AM
UPDATE: Midas was wrong it was the key.
Supercharged
HELP!!!!
Old Dec 26, 2024 | 05:35 AM
dennis black's Avatar
20 Year Member
How old is the battery in the trunk
Old Dec 26, 2024 | 09:11 AM
How old is the battery in the trunk....
Less then 2 weeks old, but it was the key bought new keys and now it working.
Old Dec 26, 2024 | 12:00 PM
stan879's Avatar
pull apart the FOB to inspect for loose connectors and that the battery is seated right. well out of case try to open car ect. if no good do the car battery thing if that works like it has been you need to find where that proximity sensor is can check that.
polarisnavyxj
Aug 17, 2016 08:50 PM
Tombloke
Sep 12, 2014 08:18 PM
Hustle Hyde
Nov 24, 2013 09:45 AM
Steve W
XJ40 ( XJ81 )
Feb 17, 2011 08:31 AM
TheGENERAL412
Oct 5, 2007 11:35 PM
