Morning noise/hit
Old Nov 1, 2015 | 12:35 PM
D.K's Avatar
D.K
Question Morning noise/hit
Hello,
I have some strange noise somewhere. It's appears only at morning (at cold car), when the car first time changes from 1 to 2 gear (maybe from 2 to 3) I can hear some hitting noise somewhere in drivetrain. It's happening only one time, after stopping (even after few seconds after it happened) the noise/ hit never appears until the next morning. It's reminds me something similar to- after living a car on handbrake at winter when it's freezing, (-20 - -30) handbrake freeze to disks and when you start moving its lets go.
I cannot understand what's that, handbrake, transmission, engine... maybe someone had/ have something similar?
Old Nov 1, 2015 | 02:37 PM
BritCars's Avatar
How fast are you going at the time? The car runs a self test on the ABS anti lock braking system when pulling away after start up. A noticeable clunk felt through the pedals. Mine is usually by about 10mph I think. The first time I pull away after starting the car
Old Nov 1, 2015 | 02:54 PM
D.K's Avatar
D.K
It's about 10-20 mph. I will check that tomorrow morning
Old Nov 2, 2015 | 01:54 PM
D.K's Avatar
D.K
Yes, it's happening at the speed ~10 mph, I think somewhere at the front.
Thx BritCars, for your answer i will consider that its ABS check, there's no errors
Old Nov 2, 2015 | 08:20 PM
n8ertot's Avatar
That's interesting. I've been experiencing much the same thing but kind of assumed it was my control arm bushings going out. Should it really be making such a clunk?
Old Nov 2, 2015 | 11:20 PM
BritCars's Avatar
Thanks DK
n8ertot - does it do it just once each journey? Or lots of times eg over bumps? If lots of times then yes - could be control arm bushings. But if once I'm guessing it's the abs
Not sure if it should be that loud - I don't remember noticing it at first when I had the car but I definitely hear it now. Particularly when I pull away in my work garage underground (slow speed for a while and no other road noise). I half hear it and half feel it through the front pedals
It's not unusual - I remember my old Volvo doing the same years ago with a sort of buzzing as it tested
Old Nov 3, 2015 | 12:09 AM
n8ertot's Avatar
Originally Posted by BritCars
Thanks DK
Just once per journey, and it's definitely a feel/hear sensation. Sounds like it's nothing to worry about. Thanks!
nigelmay
Nov 4, 2015 07:57 AM
mrplow58
Nov 3, 2015 12:16 PM
jeremys
Oct 31, 2015 09:32 PM
Dymaxxion
Oct 30, 2015 03:35 PM
Saemetric
Oct 26, 2015 08:03 PM
