Need Coolant asap will this work ?
Old Sep 13, 2023 | 11:33 AM
Jayson Duble's Avatar
Default Need Coolant asap will this work ?
My Coolant service is due, Jaguar dealership in my area is out of the coolant and on back order 130$ per gallon. Ridiculous!!!
I'm going to drain and refill the system with a friend .. will these coolants Work ? please look at link and let me know if these will work !
thanks Jag Fans
Jayson D. USA, California
My car RED 2015 Jag XF 3.0 S/C non US model AWD
https://www.carparts.com/details/Jag...E&gclsrc=aw.ds
https://www.rmeuropean.com/Products/...SABEgKlkfD_BwE
https://www.ebay.com/itm/39346934294...6tA8c5xg8RXpe0
Old Sep 13, 2023 | 12:15 PM
vfrman's Avatar
Well...the FSM for the V8 XF calls out WSS-M97B44-D spec coolant. This is a Ford specification for coolant...and it's dexcool. I just used this: Prestone 1 Gallon Orange Concentrate Antifreeze/Coolant AF888 | O'Reil (oreillyauto.com)
Old Sep 13, 2023 | 12:19 PM
Its ok IF I USE DEX-cool in a jaguar ?! my user Manuel says WSS M97B44 no D at the end but is it ok them .. I'D like to change my Fluid tomorrow you have had no issues ?
Old Sep 13, 2023 | 12:26 PM
vfrman's Avatar
I'm pretty sure any OAT coolant will work. Autozone or Orielly should be able to look up the spec for your vehicle.
Old Sep 13, 2023 | 12:27 PM
vfrman's Avatar
What color is your coolant now?
Old Sep 13, 2023 | 01:33 PM
Orange but the Manuel says WSS m97b44 I just do not want to damage anything.
the dealership cant order Jagg spec coolant for a few months on back order
Old Sep 13, 2023 | 02:01 PM
vfrman's Avatar
Orange is usually OAT coolant. If it were my car, I'd head to Autozone or Orielly and give them your car info and get the orange OAT coolant. But that's just me.
Old Sep 14, 2023 | 08:48 AM
Orange is usually OAT coolant. If it were my car, I'd head to AutoZone or O'Reilly and give them your car info and get the orange OAT coolant. But that's just me.
I would like to UPDATE everyone that reads this ... I went to another Jaguar Dealership and spoke to the master tech working in the bays . He told me... BUY the Range Rover Coolant as it is the same but 35% cheaper. so showed me both Jaguar and range rover coolant gallons. Jaguar coast 130$ a gallon where Range Over / land rover coolant has the same stickers and chemical make up but much cheaper.
anyway I found my coolant at the dealership range over side WSS m97b44- D * D variant because they do not support or make m97b44. anymore. Ford also sells the same coolant I checked the Label on the fords Coolant. Problem solved SO if your jaguar takes the Orange or Pinkish /Orange is what the tech said, Buy range rover. Same Parts, Engine cooling system. Do not fear identical.
Have a great Day Jag community
2 bottles is enough for a Flush and fill. Mix 50/50 needed.
Jayson D.
USA , California
Old Sep 15, 2023 | 05:37 AM
2018XF25T's Avatar
I use DEXCOOL on my 2018 XF
Old Sep 16, 2023 | 10:12 AM
clubairth1's Avatar
Community Influencer
Just buy the very common Dexcool. No need for anything special.
Old Sep 17, 2023 | 08:36 AM
thistle4celtic1's Avatar
I use this…$15 from Walmart.
JDog
Sep 15, 2023 10:08 AM
chillyp
Jun 26, 2022 11:01 AM
lucasschwartz
Mar 30, 2022 09:25 AM
Ikemen
XF (X260)
Nov 9, 2020 06:18 PM
jag_man653
Mar 8, 2020 06:50 PM
