New additions to my web page
Old Nov 29, 2019 | 01:48 PM
Gus's Avatar
Gus
Default New additions to my web page
I am new to the XF Forum but have been posting stuff related to XK8 & S-Type for years. Most all postings are of areas I had to correct or work on but I also have wiring diagrams and trouble codes on my web page.
Link to Parasitic testing JagRepair.com - Jaguar Repair Information Resource
Link to Service reset JagRepair.com - Jaguar Repair Information Resource
Link to oil change JagRepair.com - Jaguar Repair Information Resource
Link to Interior light and Start stop lights JagRepair.com - Jaguar Repair Information Resource
Link to Parasitic test JagRepair.com - Jaguar Repair Information Resource
Old Dec 2, 2019 | 11:49 AM
lotusespritse's Avatar
"Castrol 5w20 was what was recommended in the owner’s manual so that is what I got"
FYI, that's not what's recommended by Jaguar. It's "
Castrol Edge Professional OE 5W/20"
That is much harder to obtain, and much more expensive. But if you are going to follow manufacturer's recommendation, then you need that oil. The only place I have found it reliably is here:
https://www.roverparts.com/nxt/?keyw...l%20OE%205W/20
You should update your DIY so people know, and drain and refill your car with the right oil asap.
Old Dec 2, 2019 | 07:28 PM
Gus's Avatar
Gus
I hear your concern and I was concerned as well. The oil recommended was hard to find and was not on the shelf for easy access so I elected to check with a friend who is with Jaguar that I have been dealing with and trusted for years. I was told that that in 2015 Jaguar changed the oils to 0w20 and made it retro to 2010 for the 5.0 engine and that all they use now is 0w20 Castrol Edge. I elected to use 5w20 because of the ambient temperatures I am located in. As I stated the Castrol Edge Full Synthetic 5w20 was my choice and I felt an educated one.
Old Dec 2, 2019 | 09:01 PM
SunFlower's Avatar
SAE 0W-20 is correct. I agree with both of you. Just changed mine a couple of weeks ago and purchased the oil and filter at my Jag dealer. I was told it is more for getting the oil up to the top end (timing chains) on startup then anything else. If your ambient temps are in the cooler temps more then the warmer then all the more reason to use SAE 0W-20. Pretty sure nearly all of you here know this.
I also learned what those numbers meant that day. I've been running heavy equipment all my life and never knew this info.
$9.95 a quart is what I paid
Old Dec 4, 2019 | 09:09 AM
SunFlower's Avatar
BTW - good write ups you have there sir.
Old May 12, 2020 | 02:22 PM
Gus's Avatar
Gus
I recently added two links to my page for the XF.
Link to Starting problems related to my XF JagRepair.com - Jaguar Repair Information Resource
Link to Door licking problems related to my XF JagRepair.com - Jaguar Repair Information Resource
Old May 14, 2020 | 01:58 AM
prolepsis's Avatar
Default Can you give more info about where you sprayed lube?
Hi Gus,
Please can you provide more details about where you sprayed lube on the sticking door locks? I can't see many places to spray stuff without removing the trim. I'm very curious.
Thanks.
Old May 14, 2020 | 07:44 AM
Gus's Avatar
Gus
See if this helps.
Gus
Old May 14, 2020 | 08:43 AM
prolepsis's Avatar
Thumbs up Thanks
Old Sep 2, 2020 | 08:15 PM
Gus's Avatar
Gus
I added a few things to my webpage.
Link to Light stalk replacement JagRepair.com - Jaguar Repair Information Resource
Link to Brake pulsing issue JagRepair.com - Jaguar Repair Information Resource
Link to Emergency brake reprogramming JagRepair.com - Jaguar Repair Information Resource
Link to PVC repair P0171 & P0174 JagRepair.com - Jaguar Repair Information Resource
Link to window reset JagRepair.com - Jaguar Repair Information Resource
Link to 2010 XF Workshop manuals and Owner’s manual JagRepair.com - Jaguar Repair Information Resource
Old Nov 4, 2020 | 11:15 AM
Gus's Avatar
Gus
I should mention that the Workshop manual has ALL OBDII codes listed for the 2010 XF
Old Dec 4, 2020 | 10:11 AM
Gus's Avatar
Gus
2010 XF Oil change with vacuum extraction JagRepair.com - Jaguar Repair Information Resource
XF Brake lining sensor replacement JagRepair.com - Jaguar Repair Information Resource
XF music conversion to MP3 JagRepair.com - Jaguar Repair Information Resource
Old Feb 12, 2021 | 10:40 AM
Gus's Avatar
Gus
Posted a link on my page for XF 5.0 belt tensioner replacement JagRepair.com - Jaguar Repair Information Resource
Harry Peter Rose
May 2, 2017 03:01 PM
mghirsch
Oct 8, 2016 09:17 AM
Calahonda
Feb 17, 2015 04:26 AM
nurquhar
Aug 24, 2012 06:22 AM
phaelax
Apr 1, 2009 10:21 PM
