New alternator still saying battery not charging
Old Apr 23, 2024 | 01:14 PM
Digidave69's Avatar
Default New alternator still saying battery not charging
Hello all.. I'm new to this. I have a 2014 xf s portfolio. I recently had battery not changing come up. I had new alternator installed now still say same amd performance loss etc. Apparently the garage said something needs reprogrammed. Is this the case?
I have reduced performance now
Anyone any ideas
Dave
Old Apr 23, 2024 | 01:27 PM
John Williams's Avatar
I don't see any connection between the alternator not charging & restricted performance, unless the garage failed to refit a turbo pipe somewhere!
Old Apr 23, 2024 | 04:16 PM
Digidave69's Avatar
I thought that too I'll see the garage tomorrow. Thankyou. Any idea why still saying battery not charging although apparently it is
Old Apr 23, 2024 | 04:29 PM
Read this document pay attention to the section about the fuselink.
Old Apr 23, 2024 | 04:46 PM
Digidave69's Avatar
Brilliant. Sounds like the garage haven't followed proper procedure. Thankyou. Makes sense and would explain why still says battery not charging but if I'm understanding the page right. It days would re organise itself
Old Apr 23, 2024 | 04:49 PM
Digidave69's Avatar
Brilliant. Thankyou. Makes sense. Looks like garage haven't followed correct procedure. Would explain why still says battery not charging. But if I'm right the page you sent says it would re organise itself. Yes
Old Apr 23, 2024 | 04:59 PM
Not resetting the bms would not stop the car from charging, but if the fuselink has blown the car would only charge at 13.7v & the battery warning light would be on. (see page 3).
Old Apr 23, 2024 | 05:13 PM
Digidave69's Avatar
Ah right. And funnily enough he did say it was 13.something volts. So makes sense. I would've liked to have thought a garage would know that. Excuse my ignorance but where us the fuse link. And I'll tell them in morning in case they dint know
BTW. Thanks for replying to my questions
Old Apr 23, 2024 | 05:29 PM
There's a thin red/blue wire on the battery positive, follow that wire about 5/6 ins & there will be an inline type of fuse, this is the fuselink, that wire feeds the bms on the negative terminal.
kenc
Apr 23, 2024 05:15 PM
bjsovereign
Apr 28, 2017 02:46 AM
jmault
Aug 28, 2012 02:45 PM
baffourg
Jan 27, 2012 09:23 AM
raw13
XJ40 ( XJ81 )
Jan 5, 2009 08:10 AM
