new brake pads
Old Mar 23, 2018 | 12:26 PM
Akwarr's Avatar
Default new brake pads
Hey everyone, im sure this has been discussed but I cant seem to narrow it down in a search. Is it required to replace the brake sensor on the 380mm brakes when replacing the pads?
Old Mar 23, 2018 | 04:23 PM
OzXFR's Avatar
If the existing sensor hasn't triggered (ie worn down to the triggering point) then you can re-use it.
Problem is it's very hard to remove it from the old pad and/or clip it into the new pad without snapping part of the end/clip off, they go brittle with age and heat cycles.
Best to get a new one in case the old one snaps, they are only about $10 - $15, then if the old one goes back on OK you have a spare.
Old Mar 23, 2018 | 04:36 PM
Akwarr's Avatar
good to know thank you. My low brake pad warning has been on for about 3 days and i ordered new pads. Ill get a few sensors just in case
Old Mar 26, 2018 | 10:25 AM
Akwarr's Avatar
I ordered 4 sensors and was reading somewhere that I may only need 2. Is this correct?
Old Mar 26, 2018 | 10:36 AM
10 XF Premium's Avatar
Only need 2, but they are different front and back. So you will need one of each. Not 2 of each.
Old Mar 26, 2018 | 11:22 AM
Akwarr's Avatar
thank you. I ordered 2 front and 2 back so I guess I will send them back
Old Mar 26, 2018 | 02:44 PM
JBzXJ40's Avatar
Yep - one on RF and one on LR wheels.
You can probably still use it even if its made contact with the rotor. Just have to be careful when removing it as they tend to break.
Old Mar 27, 2018 | 01:57 PM
JTatRVSusa's Avatar
I just ordered some today as well but rear pads and sensors. $50 all said and done at Rockauto
Old Mar 28, 2018 | 06:20 PM
12XF's Avatar
Just wondering, where did you buy the brake sensors from? Part number? Thanks a lot!
Old Mar 28, 2018 | 07:50 PM
Front and rear set:
https://www.ebay.com/itm/Front-Rear-...1Y2rxV&vxp=mtr
Old Mar 29, 2018 | 11:12 AM
Akwarr's Avatar
i spent less then that on rockauto.com
Old Mar 29, 2018 | 05:25 PM
Yeah, I paid less also a while ago. That was just the most simple way to show what you need.
Old Mar 29, 2018 | 06:07 PM
Akwarr's Avatar
gotcha. Thank you
derrickonline
Jun 5, 2020 08:48 PM
aladamson
Mar 10, 2009 07:36 AM
Walter1982
Mar 1, 2009 10:14 PM
rajinder75
Oct 14, 2008 10:42 AM
ohnoesaz
Feb 14, 2007 01:16 PM
