Piece of rubber sealing: Belongs where?
Old Apr 8, 2016 | 10:56 AM
Per's Avatar
Per
Default Piece of rubber sealing: Belongs where?
I found this wedged between lower front corner of the LH front door and door jamb. Even when looking at the RH side I cannot find out where it belongs. It could of course be that it has fallen off totally at the RH side. Does anybody know where it belongs? Alternatively could you post a photo or three of the gap arounf the hinges with the door fully open?
Outside, i.e. facing the door as found.
Inside, i.e. facing the hinge area of the door opening.
Old Apr 8, 2016 | 11:57 AM
Per's Avatar
Per
OK found out where it goes: It sits beneath the upper rear edge of the front wing. Part of the wind noise sealing. The seal is damaged but I believe I can fins some sealing to repair and then back it goes with a blob of glue. No wonder I thought the wind noise had increased lately.
Old Apr 10, 2016 | 05:09 PM
nasa25's Avatar
It's behind the fender. Mine dropped out 3 years ago and I have a new piece that I still haven't installed lol
That little nipple on it breaks off and that's what causes it to fall.
Old Apr 11, 2016 | 08:04 AM
Per's Avatar
Per
I repaired and installed mine yesterday. Very fiddly. Windnoise back to low normal :-)
WhiteTardis
Apr 25, 2024 09:05 PM
Ntimd8
Apr 7, 2016 07:00 PM
byjosh
Apr 5, 2016 08:05 AM
SD96XJ6L
Apr 3, 2016 10:11 AM
TexMurphy
Apr 1, 2016 01:30 PM
