Pumping out the oil..
Old Feb 2, 2016 | 05:28 PM
Bigg Will's Avatar
Default Pumping out the oil..
So I bought this pump
to do top side XFR oil changes since I started using the WalMart Super Tech 5w20 Full Synthetic oil, I'm changing my oil every 4k mi. and changing the filter every 8k mi.
Used it a couple days ago and it works great, even used it to suck out the power steering fluid and in Higgins and my truck. I'm liking the topside oil change option with the XFR. Quick Easy and CLEAN!
And Higgins Likes Wallys Synthetic oil.
Old Feb 2, 2016 | 06:05 PM
2010 Kyanite XFR's Avatar
So I have to ask, how do you know he likes it?
Old Feb 2, 2016 | 06:16 PM
DPK's Avatar
DPK
Not trying to be a pain in the ***...But going against the Jag recommended oil is one thing, but to leave the oil filter in every other oil change, just goes against everything I've ever believed in when it comes to oil and filter changes, makes me cringe.......And I've been doing my own oil changes since 1972.
But this is just me...So, do as you feel best for the car...
Old Feb 2, 2016 | 06:36 PM
Bigg Will's Avatar
With every other oil
Mobil 1
Valvoline Syntec
and Pennsoil synthetic made with Natural gas
Higgins used between .25 and .5 qts every 3k, Higgins used 0 courts of Wally's 5w20 in 4k mi. and I like it for only $17 a Gal. I can afford to change it every 4k and find it 24hrs a day EVERYWHERE!..lol
Petroleum Quality Institute of America
Old Feb 2, 2016 | 07:24 PM
Bigg Will's Avatar
Then you also know that Jag recommends oil changes when the car tell you too, that in some cases can be up to 15,000
XF MAINT CHECK LIST.pdf
This Jag oil filter designed to last 15k mi. on NO oil change, so 1 oil change at 4k mi while using the same oil filter for 8k mi is no issue if you have no other problems with the engine, and I don't
As far as what Jaguar recommends for oil - this publication
http://www.api.org/~/media/Files/Cer...GLISH_2013.pdf
breaks down what specifications match or exceed
Jags recommendations, and this testing
proves it out, Wally's does just fine.
Only been changing oil since 78, but been NHRA drag racing since 1985.
I'ma do me, so you go ahead and do you!
Old Feb 2, 2016 | 07:25 PM
I knew you would have a well thought out reason why. That's something I can always count on you for.
DPK, why would you have an issue with that when the factory recommended intervals are twice that long?
Old Feb 2, 2016 | 07:39 PM
Bigg Will's Avatar
"I knew you would have a well thought out reason why. That's something I can always count on you for".
You know that's all I do at work beside go on test rides in the new XE with you!..
Old Feb 2, 2016 | 08:41 PM
So true!
Old Feb 3, 2016 | 07:09 AM
DPK's Avatar
DPK
Like I said..It's me and not you..And if you feel okay with this, it's your ride...Finding reasons to justify your reasoning, well, it's like the guy that seems to think 87 octane is okay in spite of 91 octane....To me it just don't make sense to leave a dirty oil filter in after you change the oil..It's also like why do you wipe your *** after you take a dump, you are only going take another dump in a few hours or so..
I really don't care how or what you do...I just stated how I feel about it if it were my car and I'm glad it isn't.
But I do like the pump idea..can you mention brand and cost maybe?
Old Feb 3, 2016 | 07:55 AM
I'm not trying to change your mind either but BiggWill's logic, going back to your two analogies is that he wipes every few hours, whether he's taken a dump or not, he just uses the baby wipes when he feels he needs to. And the 87/91 argument is more akin to him usually running straight 103 race gas but every few tanks he blends in some 91.
In either example, he's doing a lot more than what is recommended, not less. If you followed Jaguar's recommendation, you'd have oil in there almost 4x as long, with the same filter. So he has cleaner oil going through the filter half as long as recommended.
Old Feb 3, 2016 | 08:04 AM
DPK's Avatar
DPK
I understand..Thanks for the explanation..But it's just goes against my sense of well being to leave a dirty oil filter in every other oil change...it's all I'm saying. Technically and chemically I understand it's not a bad thing.
Old Feb 3, 2016 | 08:24 AM
Enough said.
Old Feb 3, 2016 | 10:30 AM
Injekter's Avatar
ALL right, ive quite wiping all together... problem solved.. ; )
Old Feb 3, 2016 | 01:34 PM
Bigg Will's Avatar
[QUOTE=DPK;1395229]Like I said..It's me and not you..And if you feel okay with this, it's your ride...Finding reasons to justify your reasoning, well, it's like the guy that seems to think 87 octane is okay in spite of 91 octane....To me it just don't make sense to leave a dirty oil filter in after you change the oil..It's also like why do you wipe your *** after you take a dump, you are only going take another dump in a few hours or so..
But I do like the pump idea..can you mention brand and cost maybe?[/QUOTE
I'm NOT justifying, just explaining. The pump can be found on EBay.
Old Feb 3, 2016 | 06:10 PM
DPK's Avatar
DPK
Thanks for all the help
Old Feb 3, 2016 | 07:22 PM
n8ertot's Avatar
So I'm missing what the pump is called. It's on ebay, but what do you search for?
Old Feb 3, 2016 | 08:16 PM
OzXFR's Avatar
It's an Aleko, see here: ALEKO | Portable Scavenge Pump.
I found it very easily by right-clicking on the image in post #1 then choosing "Search Google for image".
I'm running Google Chrome on a PC with Windows 10, so I don't know if this method will work for other set-ups.
Old Feb 3, 2016 | 09:37 PM
n8ertot's Avatar
Duh. Should have thought of doing an image search. Thanks!
Old Feb 4, 2016 | 06:40 PM
Bigg Will's Avatar
Just get about 5ft of the right size hose to fit the fixture it the oil fill on the motor as the hose it comes with is too small, and I just push the hose on with NO CLAMPS since there is nothing to stop a lose clamp from sliding down the hose, down the fixture and into the motor. I had some hose around the garage, didn't get the size off it.
Eurobahn Jaguar
VENDOR Threads
Mar 3, 2016 08:47 AM
Miss Charlee
Feb 15, 2016 06:17 PM
Rocky15
Feb 1, 2016 05:53 AM
santer
Jan 26, 2016 05:45 PM
rflexible
Jan 20, 2016 04:50 PM
