Rear door lock central locking fault
Old Jun 5, 2021 | 12:37 PM
Bikergonebald's Avatar
Default Rear door lock central locking fault
Hi Guys,
I have a fault with my rear door not always unlocking with the central locking. I’ve read it’s a common fault and I expect it is the door lock motor mechanism.
My question is.
When it becomes a permanent fault rather than intermittent is it still possible to open the door from inside?
I’ve had the fault on several VW’s and on those cars if it fails completely you have to rip the door card off then drill a hole through the door frame to access a screw.
If it fails that way on the XF I will have to get it fixed sooner rather than later.
Thanks.
Old Jun 6, 2021 | 08:33 PM
BritCars's Avatar
Yes. You can still manually open and close. Lock and unlock.
Actuator is a bit fiddly to change but not too bad. I had to do a front one. I assume rear is similar
Make sure you get the right part - it's different for cars with passive door unlocking.
danthefitter72
Nov 12, 2020 03:29 PM
lspab
Nov 5, 2020 05:18 PM
Davidvdm
Sep 4, 2019 12:53 AM
Steve50
General Tech Help
Oct 13, 2018 09:05 AM
JagNZ
Jan 18, 2013 07:51 AM
