Rear Subframe Bush replacement
Old Apr 13, 2026 | 01:20 PM
robthebritkew's Avatar
Default Rear Subframe Bush replacement
Greetings all,
Looking at replacing a load of parts on the my xfr 2011. On the rear, where the diff goes into the subframe, you have the bushes. I contacted my local Jag supplier, and they said those only come with the subframe itself, and they can't supply them individually. Does anyone know where I can purchase these bushes from. I believe there are 3 in total, two highlighted in the picture and one towards the front of the diff.
Any help would be greatly appreciated.
Thank you all
Old Apr 15, 2026 | 10:29 AM
clubairth1's Avatar
Community Influencer
Those are not the subframe bushings. Those are the differential to subframe bushings.
Here is a diagram from JPART that show what goes where.
The red circles are the 4 subframe bushings. The green circle is the 2 differential to subframe bushings and I find again in JPART that they list them separately?
You need C2P17594. Fairly cheap at $35 each from JLR and they are good current part numbers. Should be easy to get?
Note the diff bushing in the front is way different and will be a different part number as well. It looks to be a 2 piece bushing of some kind.
Strange that a dealer would give such wrong info without even checking with the parts department?
Please post back with what you do as this will become a common repair as our cars age and accumulate miles.
Did you have any noises?
Since your in a replacing mood any plans to replace those 4 subframe bushings? Your there anyway.
Old Apr 15, 2026 | 10:56 AM
RoverJoe's Avatar
Current jag parts catalog does not show them separate for a 2011 XF, but it may on other years and still be a good part#, so his dealer was just going off what they had in front of them.
Old Apr 16, 2026 | 08:40 AM
clubairth1's Avatar
Thanks Rover!
That part number should be good for any XF?
The dealers are listing this for 2014-2024 cars so it should fit a wide range of cars. But your right it does not say 2011.
These bushings have been used since the 1999 introduction of the S-Type/Lincoln LS.
Old Apr 16, 2026 | 02:21 PM
RoverJoe's Avatar
I'm sure it's the same bushing. Compared to the Land Rover side, the Jaguar parts catalog is a disaster.
Old Apr 17, 2026 | 01:07 AM
Thank you so much for this information, really helpful. I went back to my supplier and he said these parts are not listed for my car but he can get them. Is there a 3rd bushing for the differential?
Old Apr 17, 2026 | 01:10 AM
Do you have the part number for the subframe bushes too ?
Old Apr 17, 2026 | 08:22 AM
clubairth1's Avatar
No mention of VIN in JPART but do check these numbers with a dealer BEFORE ordering. I also see no superseded part numbers either. I did learn there are front and rear sub frame bushings as I had assumed all 4 were the same.
Part numbers.
One thing I found is if your interested the XFR-S uses the same front part number but the rear bushing is different. T2P1370. Don't know if you want to try that bushing or not?
Since you have an XFR you do have the E-diff.
The front rear diff mounting bushings are confusing and do reference the VIN. So there must be some differences. As posted above all the rear diff bushings have been the same for decades.
Can you post the last 6 digits of your VIN? Then we can see what comes up.
Old Apr 19, 2026 | 04:52 AM
Hi there,
Here are the last few digits from the VIN. AMR48983 I'm located in Dubai, not sure if the VINs show up in all the systems. I know it does have the e-diff as many years ago i had a fault with it. My supplier in the UK said the bushes don't show up when he looks up my VIN, which is why he didn't offer them. If you need any pictures or any other info i can get it to you. This VIN is the one from the windscreen, is there anywhere else i can identify anything that helps ?
Thank you
Old Apr 20, 2026 | 08:04 AM
clubairth1's Avatar
Yes thanks for the VIN. Using that I find these numbers.
I guess that bushing just mounts from the top and there is no bottom half.
Good news is they are valid part numbers and are available at any JLR dealer and they run about $30 each.
Not sure how difficult it will be to get them where your at?
unklebuck
Mar 17, 2026 05:31 AM
ChristmasGT
Aug 16, 2025 08:36 PM
Vauxi
Jun 17, 2024 12:31 PM
Jagluvr
Jun 7, 2018 04:47 PM
Bleujag
Aug 3, 2015 08:11 PM
