Like many of you, I have had the issue of the rattling noise in my XF. There is also a popping noise coming from the front passenger side visor area. I took my vehicle in for a service-2 days later they had replace 3 broken rear clips and 3 front clips
3 C2Z11575- CLIPS RETAINING
Got my car back today- Still popping noise from visor area and rattle/creaking a littl less than before from the roof area.
The seal has been lubed prior to this service.
Question-Does the seal around the sunroof need to be replaced? I am running out of patience with this vehicle and have brought it in for this issue twice already.
Any suggestions would greatly be appreciated.
I had a rattle in my XFR from the start - apparently coming from somewhere within the central dash. Dealer located it and said there were some bolts missing in there somewhere, which they had replaced. I was doubtful but the rattle was gone anyway. A few weeks later, the rattle returns! Eventually I located it - to the cheap plastic housing around the rear view mirror mount. It had popped apart and simply needed clipping back together. It still has some play in it, just a poor quality part. The sound never seemed like it was coming from there, probably because the sound was getting projected down to the dash by the angle of the windscreen. Maybe worth a check?
I just noticed a creaking noise in my XF since it has gotten colder out... sounds like it's coming from the dash area. Maybe the material has dried out and contracted such as our doors in our 1820's house... In the summer you can't close the doors because of the humidity/moisture in them but after November they close with ease... Could this simply be a case of contraction in the material? Possibly the result of all the sound deadening insulation… Nothing appears loos or missing clips/retainers
I used silicone lube and applied it to the rubber seal portion of the sunroof. I still hear a glass rattling noise when driving, this is so annoying. I don't know if it's worth letting the dealer look at it again. It's def not the clips. I wonder if the roof is loose some how?
I had some creaking which was coming from the driver door right where the speaker (to the left of the steering wheel) meets the rubber seal when the driver door closes. GOD it was so annoying! I brought it in and they lubed me up. It re-occurs when the weather changes, but at least now I know how to fix it.
Reaxions
close
- Join DateDec 2011
- LocationAtlanta, GA (Dunwoody)
Liked:182 Times in 124 Posts
Quote:
To your point about the cheap plastic housing, if you were to look on the inside of that housing, you would see that it says FoMoCo (Ford Motor Company). And, yes, it's complete crap quality.Originally Posted by darlo
Reaxions
close
- Join DateDec 2011
Quote:
2. get a louder exhaust
3. get old.. what WHAT did you say?
That is as helpful as I can be for my 100th post.
You're actually 100% accurate. It's not until I mute my loud exhaust and aftermarket stereo that I hear any of the rattles, like when I have a client phone call. But, those calls always seem to put me in a horrible mood. Ha-ha.Originally Posted by Gn4hir
1. turn the radio up2. get a louder exhaust
Quote:
Haha! So true. Same hereOriginally Posted by Reaxions
That's darn ironic! I need to take mine apart and it wont give. Go figure.
