Supercharger duct resonator aj813611
Old Feb 27, 2021 | 12:30 PM
kansanbrit's Avatar
Default Supercharger duct resonator aj813611
Can anybody explain the purpose of this device on the back of the 5.0L supercharger and know whether it can be deleted?
Old Feb 27, 2021 | 01:07 PM
Swilmer52's Avatar
It’s useless, just allows engine noise under load into the cabin for a “sporty” experience. It’s called a symposer, just remember to cap the hose that connects to the manifold to prevent any unmetered air from entering the engine. I completely removed mine about a year ago. No issues at all
Old Feb 27, 2021 | 01:41 PM
Oxidizer2k's Avatar
How difficult is it to remove with the supercharger in place? What does the car sound like without it?
kansanbrit's Avatar
Wow, thanks for the info, that makes the area behind the supercharger much tidier I am sure ! I just wasted my time fixing the flexible pipe :-)
Old Feb 27, 2021 | 01:59 PM
Swilmer52's Avatar
@Oxidizer2k I actually did it when I removed my blower for the rear crossover pipe. Here goes a pic of when I had the manifold cover off. Looks like it can be done without the blower completely off. Just the removal of the strut bar, wipers, and plastic bits and you should be able to get it done.
Old Feb 27, 2021 | 02:54 PM
kansanbrit's Avatar
So I assume you leave so this on (I am working on a Range Rover but probably the same)
Leave this port open?
And blank this port off ?
Old Feb 27, 2021 | 03:17 PM
kansanbrit's Avatar
Here is what you are dealing with.....
Old Feb 27, 2021 | 03:28 PM
Swilmer52's Avatar
Not the easiest job, but it can be done. The whole system can be tossed away, just remember to cap off the manifold port and the cabin access tube. Everything can be tossed away. No fault codes, no issues
Old Feb 27, 2021 | 03:38 PM
kansanbrit's Avatar
Did you agree with my assumptions above ????
Old Mar 13, 2021 | 08:24 AM
kansanbrit's Avatar
Done.
Old Mar 14, 2021 | 03:40 PM
clubairth1's Avatar
Community Influencer
Notice any difference in the sound?
Don't really care for the cabin noise myself but it's a very common feature on many cars now.
Old Oct 18, 2022 | 11:01 PM
Reaxions's Avatar
@kansanbrit What did you do with the port on the "Tuning Valve" that you asked about above in this thread? Please see pic below for reference. In another post above, where you say, "Done," I see that you apparently left an electrical connector hanging, but it looks different than the one on my XFR which goes to the tuning valve, so wasn't sure what you decided to do. Did you just leave that port uncapped or what?
Further, per the thread I started (with associated pix for reference) at Boost Reference: Brake Booster Vacuum Line @ Symposer???, the manual says, "The tuning valve controls the application of vacuum pressure to the pneumatic valve (in the Symposer). The tuning valve is a normally-closed solenoid-operated valve installed in the vacuum line between a T-connection in the brake vacuum system and the pneumatic valve." So, I'm wondering if I can somehow either use that port as a boost reference for a mechanical boost gauge or cut the vacuum line before it gets to the tuning valve, and use that cut end as a boost reference. Because the manual says that "the tuning valve is a normally-closed solenoid-operated valve" (assuming that's what the electrical connection is for???), I'm guessing that open port you asked about might not be of much use for boost at all times, if it's even a useable reference at all (which is why maybe I cut the vacuum line before it gets there?). This crap is confusing.
Thoughts?
Old Oct 19, 2022 | 11:35 AM
kansanbrit's Avatar
I actually filled the unused port with silicone rubber but probably didn't need to. No codes. You won't be able to get a boost pressure reading via the vacuum line as it is used for the brake servo. You would need to tap in to the blanking plate I showed in my photo.
dpark
Dec 14, 2020 04:19 AM
2jags1993
Sep 19, 2019 01:58 AM
Cee Jay
May 3, 2016 01:53 PM
HawaiiRealtor
Feb 1, 2016 10:05 AM
PinnacleWax
Detailing / Car care
Feb 13, 2014 01:35 PM
