TPMS question
Old Apr 18, 2020 | 03:51 PM
garysaunders85's Avatar
Default TPMS question
Anyone else ever have issues with aftermarket tpms sensors? I had 4 new aftermarkets put on, the right front threw a code, replaced again with a new one and it's still throwing the code. I bought 4 OEM ones hoping that it fixes my issue. Weird thing is, is that it's only the one throwing a code!
Old Apr 18, 2020 | 04:37 PM
Jssaab's Avatar
I just put on 4 new wheels and tires, bought VDO/Siemens TMPS sensors from Rockauto ( they are the manufacturer that makes them for jaguar) in fact they have a blank space for the jaguar logo. 20 bucks each,Shop put them on, installed the tires and wheels drove away all was good
Old Apr 18, 2020 | 04:39 PM
That's the brand I just bought as well! Hope that fixes my problem
Old Apr 19, 2020 | 11:57 AM
Jayhawker83's Avatar
Also looking for recommendations on TPMS for my 2011 XF SC. Was it the VDO SE53001 that you ordered?
Old Apr 19, 2020 | 12:04 PM
That's the part number I ordered. I also ordered the TPMS initiator as well.
Old Apr 19, 2020 | 02:33 PM
Jssaab's Avatar
I Didn't need an initiator, plug and play for me
Old Apr 19, 2020 | 03:09 PM
The TPMS sensors should be pre-programmed. I'm not sure if I have a sensor problem or it's the initiator in the fender well. The initiator is only 28 bucks so I figured I might as well get one just in case that's causing my issue.
Old Apr 19, 2020 | 07:22 PM
Jssaab's Avatar
Good luck, keep us posted
Old Apr 20, 2020 | 09:58 PM
BritCars's Avatar
I've had a lot of problems with aftermarket tpms sensors. As have others too. The jag system seems to be sensitive to non oem ones. I tried a set of good quality aftermarket ones with my winter wheels and they were great at first, then a few intermittent errors, then a lot. Tried various swaps and changes but couldn't fix and Jag dealer assured me it was aftermarket sensors. Changed them for oem jag ones (found cheap on eBay) and been perfect ever since
Seems hit and miss. They work perfectly for some people and a real pain for others
Old Apr 21, 2020 | 01:02 AM
John Williams's Avatar
You need to check that thr frequency match whats on the car, mostly 433mhz but I have read that some markets use 315mhz.
The frequency is printed on the sensor,
Old Apr 21, 2020 | 12:03 PM
Jssaab's Avatar
OE (original equipment) are Seimens VDO (major manufacturer and installed on many cars from the factory), so these are not knock-offs. (OEM means made to OE specs - but not OE and most likely Asian knock-offs))) he got the ones are Jaguar brands as their own, will be no issues
Old Apr 22, 2020 | 01:23 PM
Changed the initiator today and reset the code since I got that part first in the mail. Tpms sensors are still in shipping in Texas. So far I've driven 60 miles with out the code returning. Used to be every 25 miles the light would come back after deleting. Maybe I don't need the OEM sensors. I'll keep everybody posted
Old Apr 23, 2020 | 07:39 PM
BritCars's Avatar
In the US the older XF models are 315MHz
So definitely check with dealer for the right one for your vin
Old Apr 23, 2020 | 07:40 PM
It's definitely 315. I have a TPMS programmer. I already checked all that. It looks like my problem was just the initiator. I ended up buying four sensors because they were on clearance and I'll just keep them for a rainy day
Old Apr 23, 2020 | 07:53 PM
Jssaab's Avatar
Good that worked out and if you got those Rockauto clearance VDO units that was a great grab, I may get another set for my winter tires since they are the originals...
BritCars
May 26, 2025 07:41 PM
mrNewt
Apr 27, 2019 03:07 PM
tiger_reddy
Jul 22, 2018 02:23 AM
Sean W
May 27, 2017 12:08 PM
ilwill77
Mar 3, 2013 07:46 AM
