What does the checkered flag do on an 09?
Old Oct 10, 2015 | 09:17 PM
n8ertot's Avatar
Default What does the checkered flag do on an 09?
So I know the later years ahd adaptive suspension, but I believe the 09 doesn't. The manual just says it activates a more "dynamic driving experience" whatever that means.
So what does it actually do???
Old Oct 11, 2015 | 12:37 AM
OzXFR's Avatar
It sharpens the throttle response and gearbox kickdown (so it kicks down a little easier and earlier). Not by huge amounts but enough to notice the difference.
Old Oct 11, 2015 | 10:45 PM
n8ertot's Avatar
Good to know. I've been driving around with it on all the time and thought I ought to figure it out. Thanks!
Old Oct 12, 2015 | 05:36 AM
timfountain's Avatar
Doesn't it also turn off DSC etc.? I thought I read in the manual that you should not drive in that mode on wet/slippery road surfaces....
Old Oct 12, 2015 | 05:43 AM
OzXFR's Avatar
Nup, DSC stays on, I have experimented a fair bit with Dynamic/Sport/DSC combos on both my old XFS and current XFR (both 2010 models).
I usually drive with Dynamic mode (the chequered flag) turned on, but if it's wet and slippery I turn it off. The enhanced throttle response and kickdown can result in a "moment" in the wet before the DSC catches it.
Old Oct 12, 2015 | 08:41 AM
Blackcoog's Avatar
There are a few stages to the DSC: On, partially off, and off. In my 09 SC the when you press the checkered flag button it will partially turn off the DSC at the same time (same as tapping the DSC button). This isn't the case for all models/versions of the XF. I don't know if the XFR does this. To turn the DSC off you need to hold the DSC button for 10 seconds.
Old Oct 12, 2015 | 09:56 AM
On mine when I hold down the checkered flag, I get a DSC Off message. I have to specifically turn DSC ON at this point. This is on an 09 XF SC.
Old Oct 12, 2015 | 10:06 AM
n8ertot's Avatar
Yeah, that's to be expected. For the first drive of the day, I usually get in and activate the checkered flag, then turn DSC back on. The good thing is that it stays in flag mode for the rest of the day without doing anything to dsc.
Old Oct 12, 2015 | 06:06 PM
DPK's Avatar
DPK
"What does the checkered flag do on an 09???"
I was told by my Jag salesman that WAS CALLED "DRIVE LIKE YOU STOLE IT MODE"
newfire
Dec 5, 2017 09:49 PM
LRDog
May 21, 2012 05:42 PM
chekraze
Sep 5, 2011 05:59 PM
Frog
Jun 19, 2011 08:08 AM
jbliss
Feb 3, 2011 09:48 PM
