What happened to this?
Old Aug 9, 2020 | 02:28 PM
Porkchopcash's Avatar
Default What happened to this?
Had my XFRS detailed and ceramic coated (FYI, do it, you won't regret it).
He also detailed engine compartment. He polished the engine cover and now this hose is loose and looped over the cover. Can someone else with a 5.0 supercharged take a look and see what theirs looks like.
I don't remember the bracket on left with holes..... is something missing or should it be attached there.
Also should hose across rear of cover be tucked under. Other pics I have seen do not show it.
Old Aug 9, 2020 | 10:07 PM
index1489's Avatar
The loop is normal, my 3.0 SC has it just like that. Not sure if it’s suppose to be under the engine cover or not. I took mine off years ago to make for quicker oil changes. The engine cover is a bear to reinstall after it’s been removed.
Old Aug 10, 2020 | 04:56 PM
Yeah, I think it does just slide down vertically beside cover. Weird, never noticed it before.
Can't find good pic online that shows it.
I have heard that about engine covers and that is why I had him polish it while still on the car.
Old Aug 10, 2020 | 06:05 PM
SunFlower's Avatar
Same year, 2013 5.0 Supercharged, not an XFR-S though. No hose like that on my engine Porkchopcash. No idea. My engine cover is pretty simple and easy to reinstall. Just have to line it up and push in.
Old Aug 10, 2020 | 06:10 PM
In your first pic, it looks like it us under a bracket and mine is not. I will have to pop hood tomorrow and see if I can relocate.
Thanks for the pics.
Old Aug 10, 2020 | 06:16 PM
SunFlower's Avatar
I do see it. Let me run back out there and take another look.
Ah, you saw it too! Still going to look myself.
That hose on mine comes off the top of the engine (bracket), loops underneath the air intake tube (reverses direction) and then it connects to the port on the engine. You seem to have a "y" fitting on yours but I am sure it should be out of site, not on top of the engine cover.
Good luck and you are quite welcome.
Old Aug 10, 2020 | 07:28 PM
davetibbs's Avatar
I'm pretty sure that vacuum hose is attached upside down, it's supposed to look like the pics in SunFlower's post
The loop you have in your photos is supposed to be at the other end (it sits below the passenger side cam phasers) where vacuum hose joins an extension that goes to the vacuum pump at the bottom of the engine.
Old Aug 10, 2020 | 07:42 PM
OzXFR's Avatar
Agreed, from looking at my V6 (similar but not identical to the V8) and from memory of my XFR where there was definitely no such tube/pipe showing above the engine cover, instead it was a bit lower and under the cover. And yes that is the brake booster vacuum line which runs from the brake master cylinder to a nipple on the lower left rear of the SC.
Old Aug 11, 2020 | 04:43 AM
So upside down but still connected to correct things?
Car is running great.
Old Aug 11, 2020 | 09:43 AM
XFRS pic I found online in review of the car
..... same loop as mine.
But I distinctly don't remember it being there before.
Old Aug 11, 2020 | 10:39 AM
davetibbs's Avatar
Precisely. This pipe connects the vacuum pump on the front of the engine to the brake master cylinder at the back, so it basically just needs an airtight connection between the pipes it's connecting. You won't see any issues with it connected that way around.
Who knows, maybe some were assembled at the factory like that? I'm not aware of the XFR-S having anything at the front of the engine preventing the pipe being fitted as with other supercharged 5.0s but I guess it's possible.
Old Nov 17, 2020 | 10:14 PM
VetteOwner's Avatar
That's what my 2013 XFR-S setup looks like:
Old Nov 18, 2020 | 04:47 PM
Jssaab's Avatar
Those are 2 really clean cars, awesome
sgvkirbster
Apr 18, 2021 07:18 AM
Burch1
Aug 28, 2018 03:54 PM
PsiFox
Aug 11, 2017 12:40 AM
Arne
Sep 15, 2015 02:47 PM
hen555
Sep 8, 2015 06:06 AM
