XF Battery Disconnect Help
Old Sep 22, 2021 | 01:55 PM
John8's Avatar
Default XF Battery Disconnect Help
Hi guys,
I am having a few electric anomalies, AC kicking in when button is not pressed, drivers side mirror not dipping in reverse etc.
I think I read somewhere that the first port of call is a battery disconnect.
It is a 2013 XF 3.0 diesel. It seems to have 2 batteries but it's not a stop start model.
Do I need to disconnect both batteries and for how long?
Is there anything else I need to be aware of for example setting the vents to open, any codes that I will need to enter when connecting back up etc.
I would be grateful for any advice.
Old Sep 22, 2021 | 02:35 PM
MoJo88's Avatar
It is not advised to disconnect the battery of an XF 2012-2015. Well known issue - can lead to a corrupt BCM and render your car a non-starter.
You're best bet is to plug it in for a diagnostics scan to read the fault codes.
Old Sep 22, 2021 | 04:35 PM
John Williams's Avatar
If you have 2 batteries you do have stop/start.........why else would you have 2 batteries???
Old Sep 22, 2021 | 04:37 PM
Info here.......
Old Sep 23, 2021 | 01:02 AM
John8's Avatar
That is good to know, I will certainly be leaving it alone now...
The only fault code I have is the temperature sensor which will be done on Friday.
Old Sep 23, 2021 | 01:06 AM
John8's Avatar
TBH I didn't know that. I thought I had been through all the settings and didn't come across a stop start option. At the moment it is obviously not turned on.
Old Sep 23, 2021 | 02:53 AM
Both batteries will need to be in top condition/charge for it to work. I don't have it myself so no real experience.
Iv'e read that if there is high demand (like AC on) then stop/start won't work as the AC would need the engine running to work correctly!
Old Sep 24, 2021 | 04:14 AM
drjohn's Avatar
Just my 2 bob's worth, but I recently had my main battery replaced (I agree that 2 batteries equals stop/start), and, apart from needing to reset windows and a few other systems, everything worked well. I wouldn't shy away from battery disconnection, if it was needed.
Old Sep 24, 2021 | 06:52 AM
John8's Avatar
I was hoping that would be the answer but it seems there can be a risk.
Did you have to use any codes on re connection?
What was the reset procedure, why the windows?
Old Sep 25, 2021 | 07:36 AM
drjohn's Avatar
No codes were needed, I can't remember how to reset the windows, but it was simple. I'll see if I can find the procedure,
Old Sep 25, 2021 | 07:40 AM
MoJo88's Avatar
Old Sep 25, 2021 | 11:13 PM
drjohn's Avatar
Thumbs up
Thanks, MoJo88.
Old Apr 21, 2025 | 08:15 AM
famfirst's Avatar
Any info on door locks not working? I just changed my main battery and now my doors will not lock. I can hit the remote button and hear it attempt but it does not engage. I tried from the door itself as well with no luck. My windows work fine. Thank you for any help you may provide.
Old Apr 21, 2025 | 01:48 PM
There's a battery disconnect procedure, if not followed you can lose the locking. You will need somebody with Jag sdd to run immobilisation to recover the locking.
Old Apr 24, 2025 | 08:48 AM
dennis black's Avatar
If not experienced in these matters with the battery just a friendly heads up, do not touch the battery, simply take it to jaguar dealer, bite the bullet replace the battery ,they will use sdd to reset everything, do not tell them you have any issues, just tell them to replace the battery and let them sort things out at the same price, works every time, no headaches
jaguarxjl
Apr 21, 2025 08:18 AM
scotsgeeza
Dec 22, 2020 07:12 AM
Matteh87
Jul 23, 2020 11:07 AM
Razwan Kazmi
Apr 17, 2020 10:42 AM
BigCat09
Dec 4, 2019 03:06 PM
