XF... Performance Restricted HELP!!!
Old Jan 25, 2018 | 12:18 PM
XavierPR's Avatar
Default XF... Performance Restricted HELP!!!
I have a 2011 XF 5.0 S/C left me stranded last night. I thought it was going to be a bad coil but when I ran the scanner found misfire on both banks. Here are my codes:
P0016
P0017
P0301
P0302
P0303
P0304
P0305
P0403 - EGR
P0503 - vehicle speed sensor (VSS)
Symptoms are rough idle and when I press the gas I get no action. I suspect the EGR. Anyone out there that could help out. Thanks!
Old Jan 26, 2018 | 06:32 AM
Bigg Will's Avatar
Always start with the battery, make sure it's good.
Old Jan 26, 2018 | 09:16 AM
XavierPR's Avatar
Funny thing is my wife was in the car waiting a couple of hours before it happened (limp mode) and she said there was a battery warning on the screen so she turn the car off. When I turn on the car everything was good.
I'll replace the battery and check all the fuses before going to the dealership. Thanks! Will
Old Jan 28, 2018 | 11:53 AM
XavierPR's Avatar
The new battery didn't fix the issue. I'm going to take it to a mechanic this Wednesday but see attached errors. Car start good but then it stalls with a blinking engine light meaning is misfires going on.
Attached Thumbnails XF... Performance Restricted HELP!!!-screenshot_20180128-111326.jpg
Old Jan 29, 2018 | 02:11 PM
clubairth1's Avatar
Community Influencer
Looks like a bad crank sensor and/or cam position sensors.
Old Aug 13, 2019 | 09:03 AM
mateuszyo's Avatar
Hello
What was the cause of your problem? I have this same codes...
scotsgeeza
Dec 22, 2020 07:12 AM
robert53
Aug 8, 2020 07:54 PM
elong69
Apr 6, 2018 02:01 AM
smgdata
Feb 1, 2018 08:04 AM
drdan7
Mar 30, 2016 08:24 AM
