xfr 2012 timing chain parts needed
Old Apr 10, 2019 | 06:51 PM
craneman1's Avatar
Default xfr 2012 timing chain parts needed
Need parts
numbers and info on updated timing related parts pls
tensioners guides and other
see some on ebay and other sites but are they the updated version ?????
let me know pls
Thx!!
Peter
new xfr 2012 owner
Old Apr 10, 2019 | 07:51 PM
mrNewt's Avatar
First figure out if you have 8mm chains or not. If you don't, you will need to replace other parts as well (don't have a list for those).
If you do, you need these...
For Jaguar:
- C2Z22078 x2 - Chain primary
- C2Z28429 x1 - Guide chain
- C2Z28430 x1 - Guide chain
- C2Z28431 x2 - Blade chain
- C2Z28428 x2 - Tensioner-C
Or from Land Rover (same parts, sometimes cheaper):
- LR023048 x 2 - Chain Primary
- LR051011 x 1 - Guide Chain
- LR051012 x 1 - Guide Chain
- LR051013 x 2 - Blade Chain
- LR051008 x 2 - Tensioner-C
Old Apr 12, 2019 | 06:02 PM
craneman1's Avatar
Thx
8mm chains ? 2 different types of chains on these models?
Old Apr 13, 2019 | 05:02 AM
xfportfolio's Avatar
Originally Posted by craneman1
Thx
Yes, 8mm and 6.35mm pitch chains.
6.35mm chains are not for sale anymore, so if your chain is 6.35 you need to change camshaft and crankshaft sprockets too.
Old Apr 28, 2019 | 06:26 PM
Correction;
6,35 pitch chains for sale 6,35 pitch chains for sale
Really expensive
Old Apr 28, 2019 | 06:28 PM
craneman1's Avatar
wow thx
hope there 8mm
anyway to know without opening?
Old Apr 28, 2019 | 06:46 PM
wow thx
hope there 8mm
I used a piece of clay adhered to a stick and introced it carefully through the oil filler hole to make a mold of the side of the chain. Mine is 8mm.
Old Apr 28, 2019 | 06:48 PM
craneman1's Avatar
i will check with the local *********** if they can or want to tell me
otherwise your method will do
thx
Old Apr 28, 2019 | 09:32 PM
lotusespritse's Avatar
Originally Posted by xfportfolio
Correction; 6,35 pitch chains for sale Really expensive
less on ebay:
https://www.ebay.com/itm/JAGUAR-OEM-...-/332795922783
Even less here:
https://parts.jaguarnashville.com/oe...chain-aj811428
Old Sep 11, 2025 | 05:58 PM
lifeisgood67's Avatar
Should I replace my 6.35mm Tsubaky chain, guides, and tensioners? If so, what parts do I need from Jaguar? Or should I do a conversation for the 8.0mm INA chain belt? I have 2010 Jaguar XFR
StagByTriumph
Dec 7, 2018 06:38 AM
slanham
General Tech Help
Feb 1, 2014 06:34 PM
kdross
Sep 9, 2010 08:08 AM
