XFR Oil leak oil pan
Old Jun 2, 2018 | 09:27 PM
ariba's Avatar
Default XFR oil pan leak
Is that common to have a leak close to the oil pan?
It looks like it’s on the top side but I am not %100 sure. What gasket do I need?
Pleas if you know the part number it will help me a lot.
2011 XFR 5.0 Supercharged
Old Jun 2, 2018 | 09:45 PM
lotusespritse's Avatar
I had a leak at the vacuum pump on my white XF a couple years ago. I tighthened it down and it never leaked again.
Old Jun 3, 2018 | 12:11 AM
davetibbs's Avatar
Yes, vacuum pump is the likely culprit here. I'd just buy a new seal for it (~$25). Keep a close eye on your oil level in the meantime - these engines don't like running low.
Old Jun 3, 2018 | 01:24 AM
ariba's Avatar
Thank You for helping Lotusespritse & Davetibbs that was fast
Is this the part number C2D3771 or AJ812615 or AJ812201
vacuum pump seal
Old Jun 3, 2018 | 09:51 AM
How often do you change your oil? It looks like mud coming out of there. When mine was leaking, it just looked like oil.
Old Jun 3, 2018 | 11:27 AM
Bigg Will's Avatar
Do yourself a favor and clean your engine BEFORE you start any work fixing it. You could always run a oil UV dye test on it to verify the leak location.
Old Jun 3, 2018 | 09:34 PM
ariba's Avatar
Thumbs up
Thanks right now my XFR is oversees it's 6 hours from Dubai it's a dusty rode . I am still at MD 21204 i's almost raining every day but not there it's almost raining dust like AZ & Nevada I will be leaving the country within 1 month from now I have my brother is taking the photos for me.
I change every 4000 miles Full Synthetic 5W-20 Castrol edge.
Old Jun 3, 2018 | 10:24 PM
ariba's Avatar
I will do it thanks
Ben Sawyer
Jan 12, 2017 10:19 AM
louvit
Sep 19, 2016 09:37 AM
m1eckler
Feb 27, 2015 07:20 PM
diggitydesigns
Aug 19, 2014 09:25 AM
BStopek
Mar 3, 2013 11:30 AM
